20amp Receptacle No Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 09:54 AM   #1
20amp receptacle no ground wire
i am wiring in a 20 amp outlet where the electrician forgot to install one years ago, thought it was going to be a quick easy install, but when i pulled the wires out of the box no ground wire, just black, white, and red. would there be a reason he cut the ground? its in an AV cabinet on a 20amp breaker. any suggestions on how to ground this?
moschmo is offline   Reply With Quote
Old 12-09-2010, 10:06 AM   #2
Master Electrician
Rewards Points: 3,920
Is the wiring in pipe or NM cable?
brric is online now   Reply With Quote
Old 12-09-2010, 10:11 AM   #3
i am not to sure i can see a red shielding on the wires when they come into the box, i dont know what the electrician used when running the wires, its in the back of a cabinet which is hard to reach due to equipment or i would pull it out.
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
GFCI with no ground wire? gante Electrical 6 03-13-2009 09:17 AM
ground ? in old two wire elect system wis_remod Electrical 14 02-24-2009 11:07 AM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 12:42 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
