20amp Oven On A 40amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 06:27 PM   #1
20amp oven on a 40amp circuit
I have a GE oven model JTP18 the electrical specs state:
KW Rating
240V
3.6
208V
2.7
Breaker Size
20 Amps
I have a 40 amp circuit on #8 wire with a #10 Ground (4 wire total). I've uploaded a specs file and an install file. The specs above are on the specs file. The Install manual has no specs in it. Page 2 and 9 cover "electrical connections."
1. Since this cirrcuit is well over the oven's specs, is it okay to install this oven on this circuiit?
2. Should I replace the 40amp double-pole breaker with a 30amp or 20amp breaker?
Thanks for your feedback.
It doesn't appear the uploads were attached. Must be because I'm a newbie. The info for this overn can be found here:
http://products.geappliances.com/App...&Sku=JTP18BABB
The power ratings are at the bottom of the page. It also has links to the pdfs for specs and install on this page.
ch1965 is offline   Reply With Quote
Old 09-02-2011, 06:34 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Just replace the breaker with a 20 and get to baking cookies for us.
The Following User Says Thank You to Speedy Petey For This Useful Post:
gregzoll (09-02-2011)
Old 09-02-2011, 06:37 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,098
The 20 a breaker would provide the maximum level of safety,
and protection for the oven.
Change the 40 to a 20.
dmxtothemax is offline   Reply With Quote
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Rewiring older house WillK Electrical 12 10-13-2010 02:49 PM
Rewiring furnace electrical circuit BlueBSH HVAC 4 09-21-2010 02:34 PM
Replacing a circuit breaker tertius Electrical 9 09-24-2009 09:17 PM
Can I use a 20amp outlet receptical on a 15amp circuit? abefroman Electrical 17 01-18-2009 10:57 PM
