20A Light Switches? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 05:34 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
20A light switches?
I'm assuming that if I want to run a 20A light circuit, I need to use 20A light switches, but I couldn't find any at the store. Am I missing something?
Is it OK to use 15A switches because the current going through the switch won't be controlling 20A worth of lighting?
Journeyman Plumber
Old 01-21-2012, 05:40 PM   #2
Licensed electrician
Rewards Points: 1,622
Correct, unless you are switching a 20 amp load you can use the 15 amp switches.
plummen (01-21-2012)
Old 01-21-2012, 06:07 PM   #3
Doing it myself
Alan's Avatar
I guess then that I am actually smarter than I look. Thanks again Jim.
Journeyman Plumber
Circuit trips with 2 light switches sylercider Electrical 3 12-05-2010 10:09 PM
How many light switches? Abs777 Electrical 10 11-05-2010 12:17 PM
3 way switches with light load on both ends boutwater Electrical 2 03-07-2010 12:05 PM
Two Ceiling Light Fixture switches suddenly acting flakey!!! babalina Electrical 5 10-12-2009 07:52 PM
adding an additional light to 2 3-way switches basement_guy Electrical 10 07-20-2008 09:23 AM
