20A Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 10:57 PM   #1
Rewards Points: 81
20A Circuits
Probably a dumb question................
My dining room outlets are on a 20A circuit (20A breaker and 12 gauge wire). I am repainting the room, and will be replacing the outlets and switches with new ones. The original outlets were standard 15A outlets. I know that the 15A outlet has a 20A pass through rating, but when replacing, should I put in the 20A outlets instead?
cougar01 is offline   Reply With Quote
Old 03-05-2009, 11:02 PM   #2
Electrician
15 is fine and recommended.
chris75 is offline   Reply With Quote
Old 03-05-2009, 11:03 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
Make that 2 !
jbfan is online now   Reply With Quote
Old 03-06-2009, 08:17 AM   #4
Make that three.
rgsgww is offline   Reply With Quote
Old 03-06-2009, 06:01 PM   #5
Rewards Points: 81
OK. Thanks. 15A it is.
Out of curiosity, where/when is installing a 20A outlet recommended? Dedicated circuit only, or.....?
Old 03-06-2009, 06:07 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
The only place would be where you need it. That, and a single receptacle on a dedicated 20A circuit.
Old 03-06-2009, 07:20 PM   #7
Rewards Points: 862
So, stores like Home Depot like to sell us 20A receptacles and charge us more money when the guts are exactly the same as 15A. A mistake I made when I first started buying there.
I've still got some 20A receptacles on 15A branches because I didn't pay attention to the configuration of what I was installing. I've got to change them before I get an inspector<g>
FW
Ultrarunner2017 is offline   Reply With Quote
Old 03-06-2009, 09:07 PM   #8
Rewards Points: 150
Send a message via AIM to Bocolo
I am a bit confused. Would it not be a good idea to keep consistency on everything? 20 amp breaker - 12 gauge wire - 20 amp receptacle? I can understand where you say you CAN but I am a bit confused on where you say RECOMMENDED. You would only do the above on a dedicated circuit? These are probably dumb questions but I am trying to educate myself. What am I missing or misunderstanding? Thanks for your time and input.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 03-06-2009, 09:34 PM   #9
I buy the Pro grade receptacles
Since the prices are close on the 15a VS the 20A I buy the 20a
The Pro grade seem to be much better quality then the reg grade
With an older house (50's) I also like to be able to tell the new 20a circuits from the older 15a circuits
Old 03-06-2009, 09:39 PM   #10
Res Ipsa Loquitur
Pro grades are made better than regular grade. However, regarding 20a, nowhere in a residential home have I seen a regular need for 20a receptacles.
As said before, 20a receptacles can be used where needed on a 20a breaker using 12g wire but just take a look at your appliances etc. How many 20a plugs do you see? An occasional air conditioner maybe but otherwise none. A 20a receptacle configuration is rarely if ever used in the home- commercially yes, residential, rare if any.
The guts of a good quality 15a receptacle is the same as a 20a (therefore the 20a flowthru) but with a different faceplate configuration.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-06-2009, 10:13 PM   #11
Rewards Points: 150
I understand the rarety (sp?) of 20 amps circuit in a home. My understanding of the NEC code (I am not an electrician) is that 14 gauge wire with a 15 amp breaker is considered "minimum" on a residential property. Everything I have read so far on other books have one thing in common and that is that when doing wiring you should always consider and plan for future uses. Given that 12 gauge is not that much more expensive (probably a bit harder to run though) than 14 gauge would it not make sense to wire in 12 gauge instead? Not trying to question you, just trying to understand. I guess my simple question is: Although rarely seen, is it ok to do it? Thanks for your time.
Old 03-06-2009, 10:31 PM   #12
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Yes, run 12 gage, 20A circuits. The issue here is that 15A outlets cost .39 cents. 20A outlets cost about $6.
Most home have a number of 20A circuits, but many don't have the 20A outlets on them, because there is no reason or requirment for 20A outlets on general purpose 20A circuits run in a home, such as to the kitchen. 20A circuits are not rare in homes in the US, they have been required in areas such as the kitchen, bath, and laundry for many years.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-06-2009, 10:42 PM   #13
This is a bit misleading Jamie.
A typical standard resi grade receptacle is about $.40
A typical spec grade 15A receptacle (CR15) is about $1.50
A 20A CR20 is about $2.00
A hospital grade 20A receptacle is about $6
Old 03-06-2009, 10:57 PM   #14
Rewards Points: 150
Thanks for the information. I am starting to see some logic now. Thanks again.
Old 03-06-2009, 11:04 PM   #15
Unless you are under NEC 2008 & require tamper proof, or weather resistant (outside)
Tamper proof
Normal are now ~$1.50
Pro grade are now $5+ (20a was $2.49)
Weather & tamper ~$6+
Entire Rewire or New Branch Circuits? Typ0 Electrical 44 01-29-2009 11:54 AM
Tandem Breaker and Circuit(s) whowadat Electrical 1 01-09-2009 05:13 AM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 07:00 PM
Power circuits under leaky bathtub? Beren Electrical 1 07-23-2007 10:02 AM
One neutral for two circuits?? TronCarter Electrical 13 01-14-2007 09:21 AM
