20a Circuit, 15a Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 11:40 AM   #1
Rewards Points: 164
20a circuit, 15a outlets
I'm running 20 amp circuits in my shop for things like my routers, drill press, Sanders and shop vac, can I use 15 amp duplex outlets on them? Somewhere I remember reading on here that I could. None of the tools take more than 15 A but combined they could be more than 15 total which is why chose to do a 20 amp circuit. However 20 amp outlets are beastly more expensive, and since I don't have anything drawing 20 A I was planning on using fifteens. Is this acceptable?
ryan50hrl is offline   Reply With Quote
Old 08-27-2012, 11:58 AM   #2
Rewards Points: 13,296
As long as you have 12-2 wire and no more then a 20 amp breaker your good to go.
Old 08-27-2012, 12:00 PM   #3
Master Electrician
Need a location
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-27-2012, 12:01 PM   #4
Rewards Points: 1,442
Fifteen amp receptacles are okay on a 20 amp circuit provided you have at least two (one duplex or two singles). (added later:USA; National Electric Code)
Old 08-27-2012, 12:04 PM   #5
Master Electrician
Depends on location
Old 08-27-2012, 12:09 PM   #6
Rewards Points: 164
There in my shop, it's 12-2 wire 20 amp breaker, and it will be at least five outlets on each circuit
Old 08-27-2012, 01:31 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
By location, they are asking what country?
Coastal South Carolina
Old 08-27-2012, 01:44 PM   #8
Rewards Points: 164
Lol. Oh ya. USA
Old 08-27-2012, 02:29 PM   #9
A "Handy Husband"
rjniles's Avatar
Yes, in the US under the NEC you can use 15 amp receptacles on 20 amp circuits. They are rated as 20 amp pass through. Since you are in a shop/garage/basement they need GFCI protection (either breaker or receptacle).
And before the NEC police jump me: as long as you have more than 1 receptacle (a single duplex receptacle counts as 2.)
Old 08-27-2012, 02:48 PM   #10
Rewards Points: 1,192
Beastly is another $10?
bobelectric is offline   Reply With Quote
Old 08-27-2012, 02:48 PM   #11
Rewards Points: 164
Is there a maximum number of outlets I can have on one circuit? My intention is to put a GFCI at the beginning of each run and then have 4 to 5 other outlets on each circuit
Old 08-27-2012, 03:12 PM   #12
Licensed electrician
Rewards Points: 1,266
You will be fine with 4-5 downstream of the GFI.
Best tools and efficient method for identifying outlets on a circuit, please. justplumducky Electrical 9 07-08-2012 10:27 AM
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 11:43 AM
120-V outlets and 240-V outlet on same double-pole circuit? Daneel Electrical 24 04-04-2012 12:22 AM
how many outlets do you recommend on 15A circuit? Jeremy Hillary Boob, PhD Electrical 10 03-03-2012 12:16 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 03:40 PM
