-   -   20a circuit, 15a outlets (http://www.diychatroom.com/f18/20a-circuit-15a-outlets-154992/)
ryan50hrl 08-27-2012 10:40 AM
I'm running 20 amp circuits in my shop for things like my routers, drill press, Sanders and shop vac, can I use 15 amp duplex outlets on them? Somewhere I remember reading on here that I could. None of the tools take more than 15 A but combined they could be more than 15 total which is why chose to do a 20 amp circuit. However 20 amp outlets are beastly more expensive, and since I don't have anything drawing 20 A I was planning on using fifteens. Is this acceptable?
joecaption 08-27-2012 10:58 AM
As long as you have 12-2 wire and no more then a 20 amp breaker your good to go.
andrew79 08-27-2012 11:00 AM
Need a location
AllanJ 08-27-2012 11:01 AM
Fifteen amp receptacles are okay on a 20 amp circuit provided you have at least two (one duplex or two singles). (added later:USA; National Electric Code)
andrew79 08-27-2012 11:04 AM
Depends on location
ryan50hrl 08-27-2012 11:09 AM
There in my shop, it's 12-2 wire 20 amp breaker, and it will be at least five outlets on each circuit
rjniles 08-27-2012 12:31 PM
By location, they are asking what country?
ryan50hrl 08-27-2012 12:44 PM
Lol. Oh ya. USA
rjniles 08-27-2012 01:29 PM
Yes, in the US under the NEC you can use 15 amp receptacles on 20 amp circuits. They are rated as 20 amp pass through. Since you are in a shop/garage/basement they need GFCI protection (either breaker or receptacle).
And before the NEC police jump me: as long as you have more than 1 receptacle (a single duplex receptacle counts as 2.)
bobelectric 08-27-2012 01:48 PM
Beastly is another $10?
ryan50hrl 08-27-2012 01:48 PM
Is there a maximum number of outlets I can have on one circuit? My intention is to put a GFCI at the beginning of each run and then have 4 to 5 other outlets on each circuit
Jim Port 08-27-2012 02:12 PM
You will be fine with 4-5 downstream of the GFI.
