Old 11-12-2009, 06:04 PM   #31
Wire Chewer
Red Squirrel's Avatar
20A circuit on 14/2
Originally Posted by Scuba_Dave View Post
My 7a drill pulls 2.5a while running - no load
Under load - wood bit it pulls 2.75a
So if you are going by nameplate or device rating that is probably off
I use a Kill-A-Watt to check actual draw
I was thinking that too, there was zero load on the drill as far as making the motor work. Making it drill through something hard is probably where it uses more.
As for the original issue think I'll just play it safe and replace those 20 amp breakers with 15 amp ones. Just need to find a weekend day that it's bright out. DST sucks. I get home and by 5:00 and it's pitch black.
Old 11-12-2009, 06:37 PM   #32
20A circuit on 14/2
Originally Posted by spark plug View Post
I hesitated whether to reply to your post with repeating your post. (Since I don't (yet) know how to fraction a quote. (Shame on me).
Just delete the part of the quote you don't want. Make sure you leave the little boxes with quote written at the beginning and the end.
Plumbvoltage is offline   Reply With Quote
Old 11-12-2009, 07:07 PM   #33
Electrical Contractor
20A circuit on 14/2
Originally Posted by Yoyizit View Post
You already have the wiring in place.
Run 20A or 25A through it with two hair dryers and several incand. lamps and see if any section of the wire gets hot enough to ignite tissue paper.
Here's the touch test:
no burn ever at 42°C(108°F)
burned in 30 sec at 54°C(129°F)
5 sec at 60°C(140°F)
1 sec at 71°C(160°F)
The cable may take 15 mins to stabilize at its final high temp.
That has got to be one of the most asinine post you have written.
Deliberately trying to overload a circuit to see if the breaker trips, or the wire gets warm.
Just crazy!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-12-2009, 08:28 PM   #34
Wire Chewer
20A circuit on 14/2
Just crazy!
Best to do it on purpose and be around then have it happen by accident and not be around.
But my best bet is just swapping the breaker and have better piece of mind.
Old 11-12-2009, 09:05 PM   #35
Smile
20A circuit on 14/2
Thank you. I'll try that. My answer to why I didn't try such a "Simple" procedure is so funny you'll crack up laughing, and some of the audience will think that they reached Comedy Central rather than DIY! (Now the phrase that I made up "Eliminate confusion Through education" surely applies to me!
spark plug is offline   Reply With Quote
Old 11-12-2009, 09:17 PM   #36
Lightbulb
20A circuit on 14/2
Originally Posted by Red Squirrel View Post
Hmm how would a fire start on 14awg wire if the amp draw is not even close to what the wire is rated for? Even though it was on the improper breaker it was only drawing a couple amps. Did they just blame it on the wire because it's the only thing they saw that was wrong? I would almost suspect the light itself got too hot and burned or something. OR did it have an arc fault that caused a short and burned the wire before tripping the breaker?
Not to nitpick. But you stated that "It did have an Arc Fault that caused a short" An Arc Fault does not, and need not cause a Short. It is like having a set of matches inside the ceiling or wall that keeps trying to ignite the building material until it "succeeds". Eliminate confusion Through Education ; Don't Drink and Drive, Ever!!!
Old 11-13-2009, 12:03 PM   #37
It was a dark and stormy
Yoyizit's Avatar
20A circuit on 14/2
asinine
idiotic
unethical
unpatriotic
politically incorrect
certifiable
You ain't seen nothin' yet!
http://en.wikipedia.org/wiki/Ad_hominem
Old 11-13-2009, 02:55 PM   #38
Thumbs up
20A circuit on 14/2
Just to mitigate the impact of the comments by JB fan and the poster downstream. I don't know if you are a practicing Electrician. But to an electrician, the worst nightmare is an electrical fire. And no one else like an Electrician realizes how close to disaster one can get when you straddle the line. But no one set out on an "Ad Hominem" attack. I'm sure you approached it from a purely scientific point. Do you know that Nikola Tesla once blew up the power supply of an entire town with one of his experiments. On this website, I don't think anyone can compare to the knowledge of formulae and calculations the way you do. (No matter what)Don't Drink and Drive, Ever!!!
Old 11-13-2009, 03:35 PM   #39
Xtreme DIY'r
20A circuit on 14/2
I think I would setup a test 14-2 circuit that was not in the wall if I really wanted to test this
My 1st item would be a 1500watt heater running to use most of the 1800w
Then additional 100w light bulbs that could be plugged into a power strip to raise the wattage
I was never really worried about breakers tripping when they were supposed to
Until my I noticed water dripping out of my mom's panel
Water was coming from inside the feed wire sheathing into the panel
Never been so freekin scared as when I realized that
---standing there barefoot outside my basement bedroom in a puddle
Electrician replaced panel, main feed & all the breakers (maybe meter too)
He said some breakers were so rusted they probably would not have tripped
Old 11-13-2009, 03:55 PM   #40
Yoyizit's Avatar
20A circuit on 14/2
I did this. The temp rise from 20A flowing through #14 Romex was hardly detectible with a thermistor embedded under the outer jacket.
A dryer outlet supplied the 20A and it took 15 minutes for the temp. to stabilize.
You can check breaker performance against their trip curves by drawing enough current to trip the CB in 10 secs or 100 secs, depending on your load.
You can also check the 1/2 cycle trip time by vaporizing a small gauge copper wire, but that is not for DIYer's.
Sultini, where ya' been? The place hasn't been the same without you!
BTW, I heard Tesla wrecked a building in Chicago by spinning an eccentric flywheel at the building's resonant freq.
Old 11-14-2009, 08:11 PM   #41
Thumbs up
20A circuit on 14/2
My 1st item woudl be a 1500watt heater running to use most of the 1800w
I was never really worried aboiut breakers tripping when they were supposed to
When I posted my piece (#39) there was another poster, bet. my post and yours. That's who I meant by "The poster downstream". What happened to that post???! When there's water seeping in in an overhead Service, it's usually the Cap at the Service head. Or the flange at the base of the riser. (The meter box). A Con Ed Service Technician once told me that it used to be a policy at the Co. that whenever they had water seeping in on a new service, they wouldn't get paid for the week. (The crew that worked on that service). p.s.; The above was said ONLY on Underground services where it could be established to be their fault.
Old 11-14-2009, 08:56 PM   #42
Thumbs up
20A circuit on 14/2
I took that story and many others from a book called "Man out of Time", the biography of Nikola Tesla. One of the other fascinating stories is the way the Great Thomas Edison took advantage of the newly landed immigrant by asking him to repair the lights on the cruise ship that belonged to Morgan (Edison's financier), promising to to pay him a nice amount. In the end he didn't pay him anything. (No matter what)Don't Drink and Drive, Ever!!!
Old 11-14-2009, 10:49 PM   #43
Wire Chewer
20A circuit on 14/2
The circuit I was testing is mostly all visible, it does end up going in the wall but if I do my test before the line hits that area then it should only get hot starting from where I test - up to the panel, right?
And that water incident sounds scary. :o I never realized the dangers of water + electricity until I decided to see how many 9 volt batteries it takes for me to get a shock. I can confirm: 13. Just to say I can feel something. But if I lick my fingers, it 10x more painful of a shock.
Old 11-14-2009, 11:13 PM   #44
Yoyizit's Avatar
20A circuit on 14/2
Yes. The conductor upstream of the breaker is probably much more Circular Mils than the #14.
For worse case, wrap a few inches of the exposed wire in thick fiberglass insulation and pass your current. After 15 minutes I doubt the wire under the insulation will even feel warm to your touch.
If you have one of those indoor thermometers with an outside sensor you could get an accurate temp reading using that sensor.
Here's another way to do it if you have one of these \/
http://www.elexp.com/solder/D650.jpg
Substitute a shorted length of #14 Romex for the tip of this gun, and adjust the wire length for the current desired. Try a 3' length to start. You'll need an ammeter to check your draw.
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Need a wiring diagram Mooreski Electrical 46 03-12-2011 04:25 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Using 14/2 wire on 20 amp circuit mohairy Electrical 1 12-29-2007 07:26 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
