20A Breaker Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 06:40 PM   #1
20A breaker question
Newbie question: I live in an old building and just noticed that our fixtures rated for 15A/125V (outlets, lights, etc.) are tied into a 20A breaker (wiring is 12g). Is it OK for the breaker to be 5A higher than the fixtures?
Southbound is offline   Reply With Quote
Old 02-28-2013, 06:43 PM   #2
Electrical Contractor
kbsparky's Avatar
If you are in the US, there should be no problem.
-KB
Old 02-28-2013, 06:53 PM   #3
I am no electrician, but my understanding is that if there are more than one outlet on the circuit & the wire is rated for 20 amps (12/2 for example) & the outlets are rated for a pass through of 20 amps, than this is OK. Please have someone else verify this though.
chris_b is offline   Reply With Quote
Old 02-28-2013, 08:19 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
What most people fail to realize is that a 15A duplex receptacle is TWO 15A receptacles on one yoke.
Old 02-28-2013, 08:27 PM   #5
Rewards Points: 1,192
Then that would be on a 30 amp fuze.
bobelectric is offline   Reply With Quote
Old 02-28-2013, 08:51 PM   #6
I don't get it.
Old 02-28-2013, 09:17 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
A typical 15A duplex receptacle is rated for 15A.....it will only allow devices rated for 15A or less to be plugged in.
A 20A receptacle has a slightly different arrangement...
So, a device with a 20a plug can't be plugged into a 15a outlet.....
Clear as mud?
ddawg16 is online now   Reply With Quote
Old 03-01-2013, 03:43 AM   #8
Rewards Points: 166
15 amp receptacles are fine on a 20 amp circuit in a residence. The wire gauge is more important. The only really good reason to get 20 amp receptacles is if you have a device with a 20 amp specific plug. Those are very rare.
dftc is offline   Reply With Quote
Old 03-01-2013, 04:56 AM   #9
15 amp receptacles are rated for 20 amp pass thru, if you choose to do instead of wirenutting.
Old 03-01-2013, 08:33 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,106
If there is more than one outlet it is quite normal !
dmxtothemax is online now   Reply With Quote
Old 03-01-2013, 10:13 PM   #11
Rewards Points: 1,448
Ordinary Underwriters Laboratories rated 120 volt light fixtures may be installed on 20 amp circuits. Switches rated for 15 amps may be installed on 20 amp circuits although the wiring downstream still has to be at least 12 gauge. The minimum two receptacle requirement is satisfied with one duplex or two (typically round) singles.
Circuit breaker testing newbie question kyryk Electrical 22 08-05-2012 10:12 AM
Question about tandem breaker mjarema414 Electrical 27 05-10-2012 08:39 AM
breaker question tav1 Electrical 6 11-15-2011 01:34 PM
Heating question on main panel breaker, 15A viper Electrical 5 04-04-2011 08:31 AM
breaker amp rating question Red Squirrel Electrical 4 07-18-2009 11:01 PM
