20A Breaker Load - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 07:53 AM   #1
Always working
20A breaker load
I had my electrical service upgraded to 200 Amp and while adding a breaker the other day I noticed that the electrician had attached two 12Ga wires to one 20Amp breaker (2 black hots to 1 breaker). I didn't think this was allowed (code). I thought the rule was 20A breaker, connect 12Ga wire. 15A breaker, connect 14Ga wire. Did my electrician wire this correctly or not?
Thanks in advance for any advise.
CarlV is offline   Reply With Quote
Old 01-18-2012, 07:55 AM   #2
Julius793's Avatar
Are you sure it isn't a double breaker?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-18-2012, 08:08 AM   #3
Always working
It's a single breaker.
Old 01-18-2012, 08:09 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Depends on which brand/model of single pole breaker yo have,picture?
plummen is offline   Reply With Quote
Old 01-18-2012, 08:19 AM   #5
Always working
Apologies, I'll post a pic tonight.
Old 01-18-2012, 09:10 AM   #6
MarginallyQualified
Rewards Points: 2,464
Below are two example pictures.
The right one is "no" (two wires under one screw)
The left one is "yes" (one wire each in a spot meant for one)
The Following User Says Thank You to TarheelTerp For This Useful Post:
plummen (01-18-2012)
Old 01-18-2012, 09:14 AM   #7
Julius793's Avatar
If it's a single breaker it depends if it is rated for 2 screws, however you will still want them on two separate breakers because now you limiting 2 lines to 20 amps together.
Old 01-18-2012, 10:14 AM   #8
MarginallyQualified
however you (may) still want them on two separate breakers because you (may be) limiting 2 lines to 20 amps together.
otoh... if done correctly, doubling up may have been a perfectly fine and quite expedient method to join two small or common nature circuits into one.
other methods would be making that connection in a j box somewhere or a jbox right next to the panel or wirenutting them together right inside the panel with one pigtail to the breaker...
OP: what does the panel schedule say these circuits are for?
Old 01-18-2012, 01:34 PM   #9
Always working
TarheelTerp, yes, it's like your left picture. One wire on each side of the screw. So I take it from the comments that this is ok as long as the load would not exceed 20A.
Old 01-18-2012, 01:53 PM   #10
MarginallyQualified
You're good to go.
Old 01-18-2012, 01:57 PM   #11
Always working
You're good to go.
Thanks so much!
Faulty Breaker? bpm Electrical 4 08-09-2011 06:17 AM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 06:27 PM
Sub Panel install eagertolearn Electrical 17 01-23-2010 05:39 PM
New GFCI Breaker trips with no load bmurphywa Electrical 6 04-06-2008 08:48 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
