20A Breaker, 14 Gauge Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 02:29 PM   #1
20A Breaker, 14 gauge wire?
I'm upgrading my panel and need to buy the new breakers. Some of the circuits are new but most of them will be swung over from my existing panel which is a 40A with push-button type breakers from the 1950s. All of the existing wire in my house is the black cloth-covered NM wire with no ground. All of the breakers are 20A but as far as I can tell, the existing wire appears to be #14. I am basing this guess on the fact that it looks slightly smaller than new #12 ROMEX and also the fact that you can push this older wire into the holes on outlets and switches where the new #12 will not fit and has to be attached by screws.
I know that 14 gauge wire has to be on a 15A breaker and that's what I plan to do unless someone here can give me a reason why this old wire would be safe for a 20A breaker.
Was this a mistake made when the house was built? Were wire ratings downgraded some time in the past for safety reasons? Or is there a possibility that this older wire is somehow rated for 20A even though it appears to be smaller than 12 gauge?
joside is offline   Reply With Quote
Old 08-24-2010, 04:22 PM   #2
#12 is 5/64" in diameter, #14 is 4/64" = 2/32" = 1/16".
If you wrap 10 turns of each around a dowel and measure the length of your new "coil" it will be easy to measure the diameters to pretty good precision with just a ruler. No micrometer needed. Just divide the coil length by 10.
Old 08-24-2010, 04:22 PM   #3
Electrical Contractor
kbsparky's Avatar
Change `em to the proper size. You can check the wire size using the slots in a pair of wire strippers, or an AWG gauge (not to scale):
-KB
Old 08-24-2010, 04:59 PM   #4
Unfortunately I won't be changing them because that would mean busting tons of holes in my plaster walls and is not a project I want to tackle at the moment. Maybe at a future date. Thanks for the tips on sizing.
Old 08-24-2010, 05:09 PM   #5
Rewards Points: 286
If you do decide that they are 14 guage, you are safer to replace those breakers with 15 amps then change back to 20 amp when you upgrade the wire. It's better to trip a circuit breaker than fry a wire.
Jim F is offline   Reply With Quote
Old 08-24-2010, 07:07 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
[i
I wouldn't count on the strippers. I have some that are basically a full size off. I use the #14 for #12 wire, #12 for #10 and on and on.
that wire gage is kind of funny. They provide a hole of the proper size but rather than just punching the right sized hole, they put an undersized slot to the edge. Why?
Old 08-24-2010, 07:17 PM   #7
Rewards Points: 150
yeah why not just build a new house too while you're at it
johnnyboy is offline   Reply With Quote
Old 08-24-2010, 07:49 PM   #8
Rewards Points: 156
You poke the wire in to the hole from the back. if it can slide out the slot, it's the next smaller size. Without the slot, you could poke a #14 wire into the #12 hole, and it would fit, and you might misidentify the wire.
moondawg is offline   Reply With Quote
Old 08-24-2010, 08:56 PM   #9
nap
You talking to me?
nap's Avatar
makes sense. I can't tell from the pic if it is that way so I'll take your word for it.
so, in other words, it's a go/no go style gauge.
Old 08-25-2010, 06:06 AM   #10
kbsparky's Avatar
The slot is what reads the wire size, NOT the holes.
-KB
Old 08-25-2010, 06:31 AM   #11
Rewards Points: 1,192
Yoyizit, Never heard of that method.
bobelectric is offline   Reply With Quote
Old 08-25-2010, 06:31 AM   #12
Rewards Points: 756
It's possible you are reading the numbers for stranded wires on your strippers. #12 stranded fits well in the #10 solid hole and so on. Some strippers are marked for both stranded and solid and show this "one-size-off" phenomenon.
Mark
busman is offline   Reply With Quote
Old 08-25-2010, 09:41 AM   #13
Thank you . . .I think
I never thought I would give anyone credit for being curious, but
I have to give you credit for being curious.
If you get a wire size using this method that comes out between sizes, like AWG #13 which is 0.072" inches in diameter, or some other unlikely answer, use 20 turns and divide by 20 and use a ruler graduated in 32nds or 64ths.
I don't know of a wire manuf. deliberating putting less copper in Romex that is marked with a certain size, but, hey, this is America! Who's to know?
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 03:15 PM
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 09:57 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Wire gauge recommendations please Snowdog Electrical 33 08-22-2008 03:54 PM
Gauge Wire and Breaker Discrepancy broken_scout Electrical 26 12-22-2007 10:07 PM
