20a - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2008, 05:50 AM   #1
20a
Hello, new to the forum....lots of great advice on here.
I am a new homeowner and the house was built in '68. The outlets are all brown with no ground plug-in. The breaker (switches) say 20 on them, so I am assuming I need to buy 20a outlets, right?
Next, do I wire the ground to the new outlet or just leave it screwed in the ground screw on the metal outlet box?
Thanks for any and all advice.
ripnlip is offline   Reply With Quote
Old 07-26-2008, 05:54 AM   #2
oh yeah, I forgot
I also want to change out some wall sconces. Do I wire the ground to the new light or leave that wired/screwed to the metal light box??? I havent looked at the new sconces, so they may not even have the option to wire in the ground directly to them.
Thanks again!
Old 07-26-2008, 08:47 AM   #3
Electrician
15amp receptacles are allowed be code on a 20 amp circuit
You can buy self grounding receptacles, or use a pigtail. This is of course if the boxes actually have a legal ground to begin with.
chris75 is offline   Reply With Quote
Old 07-26-2008, 09:22 AM   #4
Res Ipsa Loquitur
No, only if you had a single outlet on that one breaker would it need to be a 20a- if you have a circuit of them- (4 ~ 8 receptacles for instance) they could be of the 15a variety.
"Next, do I wire the ground to the new outlet or just leave it screwed in the ground screw on the metal outlet box?" If it is screwed to the box I am taking a grand assumption that it is grounded back to the breaker panel which is what you want. To be very sure of the outlet ground you might want to disconnect from the screw and pigtail (wirenut) that wire and two others with the same gauge bare wire- one going to the ground screw on the box, one to the ground on the outlet.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
