09-27-2012, 03:27 PM
#1
208V/3 Phase Wiring Question
I have a question about the wiring of 208V/3 phase outlets. I believe that the wiring color code for 208V/3 phase is L1 => Black, L2 => Red and L3 => Blue (along with Neutral => White and Ground => Green). However, outlets are usually labeled X, Y and Z, rather than L1, L2 and L3. Depending on how an outlet is wired, you can have either clockwise or counterclockwise phase rotation. Shouldn't there be a standard way of wiring outlets so that the phase rotation is consistent from outlet to outlet?
The reason I'm asking is that I work at a place that has 208V/3 phase power, and the phase rotation varies from outlet to outlet. This is a pain, because every time I move a piece of equipment, I have to check the phase rotation of the outlet and potentially rewire the equipment.
I suggested to our Facilities department that we adopt a standard method of wiring our outlets: L1 (Black) => X, L2 (Red) => Y and L3 (Blue) => Z. That way I can move equipment around without any problems.
They looked at me like I had two heads. Am I missing something here?
09-27-2012, 04:17 PM
#2
Licensed Electrical Cont.
You CANNOT have a "standard" to keep rotation consistent. You cannot be sure that every panel is wired the same, so even with a color standard there is no guaranty.
What you should do is have a rotation standard instead of, or in addition to, a color standard. Every receptacle that is installed should be rotation checked and kept consistent.
Do you have a phase rotation meter?
Also, 208V-3-phase does not have a neutral. It's just three phase conductors and a ground. 120/208V-3-phase would have a neutral.
09-27-2012, 04:43 PM
#3
JOATMON
In my world....we typically use Orange/Brown/Yellow for the 3 phases...
And like speedy said....you just have to test for rotation. It's a normal part of startup. If fact, it's sort of a contest to see how many motors are wired right the first time. Overall I would say it's running about 50/50.
And it wouldn't be the first time that the PoCo changed the incoming phasing after doing some work. Customer comes in the next morning and all the motors are running the wrong way.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
09-27-2012, 05:55 PM
#4
Lic Electrical Inspector
In my world brown yellow orange is 480V 3 phase. Black red blue is 208V 3 phase.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
The Following 6 Users Say Thank You to electures For This Useful Post:
09-27-2012, 05:58 PM
#5
I don't know which world you live in..... The BOY colors Brown Orange Yellow is usually used for 277/480
Electricity will kill you if you give it a chance
The Following 2 Users Say Thank You to Julius793 For This Useful Post:
09-27-2012, 06:06 PM
#6
JOATMON
My 3 phase world is 480vac....
Except as noted....no real standard....just 'practice'....
Since 1975, the U.S. National Electric Code has not specified colouring of phase conductors. It is common practice in many regions to identify 120/208Y conductors as black, red, and blue. Local regulations may amend the N.E.C. The U.S. National Electric Code has colour requirements for grounded conductors, ground and grounded-delta 3-phase systems which result in one ungrounded leg having a higher voltage potential to ground than the other two ungrounded legs. Orange is only appropriate when the system has a grounded delta service, regardless of voltage.
The Following User Says Thank You to ddawg16 For This Useful Post:
09-27-2012, 06:22 PM
#7
Must be a Kalifornia thing. And I have to say I'm not sure I buy this.
I have NEVER seen a POCO do this. Most go through some very strict rotation test and verification to prevent this. The liability is WAY too high not to.
In the litigation state of California I find it hard to believe that would be nonchalant about rotation.
The Following User Says Thank You to Speedy Petey For This Useful Post:
09-27-2012, 06:24 PM
#8
JOATMON
Actually....it was a Tucson AZ thing....went to a customer site after a lightning strike took out a transformer....lots of motors were running backwards.
09-27-2012, 06:28 PM
#9
So that was one time. Was there a second?
You made it seem like it's something not uncommon.
09-27-2012, 07:14 PM
#10
Semi-Pro Electro-Geek
That has the potential to damage or destroy some types of equipment, and could be a hazard to people with conveyors and cutting equipment. It has to be extremely uncommon.
09-28-2012, 12:08 AM
#11
" Euro " electrician
In my world. ( In France ) Black , Red , Brown or Black, Grey , Brown is 415 volts three phase,
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
09-28-2012, 10:41 AM
#12
JOATMON
And then another time in Belfast, N Ireland....specifically...at the old Delorean plant (Dunmurray Park)....new transformer for an autoclave...there was a wireing issue...when it was hooked back up, all of my motors were phased wrong.
In my case, I deal with stuff that pulls a lot of amps....2000 + is not uncommon.....hence, there tends to be little mini substations near our MCC's.
Ok...now that I think of it....it's only happened twice....
But it has caused me to make sure all the stuff in my house is phased right. My wife gets upset when the washing machine runs backwards.
09-28-2012, 12:22 PM
#13
Master Electrician
We generally use red black blue for 120/208 and orange Brown yellow for 347/600.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
