208 Volt Tankless H2O Heater On 240 Volt Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 01:52 AM   #1
Rewards Points: 1,016
208 volt tankless H2O heater on 240 volt circuit?
Can get it really cheap, so looking to find out if I can use it.
Would be used at a low usage sink in my garage workshop.
Chronomite SR-20L 208v Instant-Flow SR Tankless Water Heater
http://www.atanklesslife.com/product...er-Heater.html
thx in advance!
Vince
Old 03-19-2011, 05:32 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
I suspect that since the unit is not dual rated 208/240, using 240 on a 208 (15% over-voltage) device will shorten its life. Maybe to the point of instant burn out.
Coastal South Carolina
Old 03-19-2011, 05:58 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,864
The product manual shows models with several different voltage ratings, including a separate model for 220/240V. However, it's worth noting that the supposedly-different model for 220/240V has higher rated wattage than the 208V unit - by about the amount one would expect for a 208V unit connected to 230V or so. I think they are the same unit. It will probably work fine.
mpoulton is offline   Reply With Quote
Old 03-19-2011, 06:56 AM   #4
A "Handy Husband"
rjniles's Avatar
IMO, if they were the same unit they would not bother with the inventory control issues of having 2 units. They would have one unit rated 208/240 with a separate wattage listing. You might want to contact the company's customer/technical service for the real answer as we are guessing.
Old 03-19-2011, 08:48 AM   #5
I=E/R
a7ecorsair's Avatar
thx in advance!
Vince
How cheap is cheap? The link shows all models at $153 which is pretty cheap Have you found one for less than this? If not, just get the right one.
a7ecorsair is offline   Reply With Quote
Old 03-19-2011, 12:17 PM   #6
really cheap... fell off the back of the truck cheap.
Old 03-19-2011, 12:27 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I didn't look into the actual unit but if there are any electronic controls, there may be a problem. If there are electronic controls, you might want to look inside to see if there is a transformer with multiple taps that can be changed to reflect the proper supplied voltage.
Old 03-19-2011, 12:28 PM   #8
Rewards Points: 58
I should not matter anyway. 230 Volts on a 208 element sounds fine to me. But like the others mention, why not just get the right one for your voltage?
Old 03-19-2011, 01:21 PM   #9
Electrician
Rewards Points: 760
I have ran into this issue before. We received the 208V unit and I was about to hook it up to 240V, but didn't notice a 208/240V rateing. I called the manufactuer and they told me it was dual rated and if i hooked it up the warranty would be void.
I'm with everyone and saying to go by the right unit for your voltage, doesn't seem like there very expensive.
darren is offline   Reply With Quote
Old 03-19-2011, 02:18 PM   #10
As to the recurring question of why not just by the one for 240volt - because if I can use this one it's over $100 cheaper. Not a huge amount, but not chump change either...
As to longevity, the usage is very light - a sink in my garage / workshop.
I don't see anything much for controls that are affected by voltage - appears there is basically a flow switch and the heating element.
Thanks everyone for their input.
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
tankless water heater brewmastr Plumbing 7 01-09-2011 10:57 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
Tankless Hot Water Heater - One Fauset Does Not Have Hot Water? vsheetz Plumbing 1 10-29-2008 12:18 AM
Tankless water heater vs. electrical water heater? imola ghost Electrical 19 09-08-2008 03:59 PM
