200A Service Upgrade - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2015, 11:40 AM   #1
DIY Expert
Rewards Points: 73
I've been trying to get a straight answer now from a few electrical stores and a retired electrician and it seems like their answers vary.
So first off I currently have a 100A service. At the weatherhead to the meter it looks to be SER 2/0-2/0-2/0 Al wire. From the meter its has SEU 2/0-2/0 Aluminum.
I'm upgrading to a 200A 120/240 panel and cleaning the mess up in the panel. I've been told to run SEU 4/0-4/0-4/0 Al wire which I think having a 4/0 neutral wire isn't necessary, right?
I originally wanted to do with a SER 4/0-4/0-2/0 Al from the weatherhead to the meter and then SEU from the meter to the panel but it seems like everyone is trying to have me go with only SEU, why?
From the weatherhead to the meter socket it will be in conduit and then exposed (not in conduit as it goes through the wall) from meter to panel.
Should I just go with SEU 4/0-4/0-2/0 Al like the salesman at the mom and pop electrical stores said or am I correct with doing, SER to the meter then SEU from meter to panel?
If so, this is correct then, right?
SEU
http://www.nassauelectrical.com/prod...eu-4-0-4-0-2-0
SER
http://www.nassauelectrical.com/prod...er-4-0-4-0-2-0
TIA
doublejz is offline   Reply With Quote
Old 04-27-2015, 12:03 PM   #2
Licensed electrician
Rewards Points: 1,478
SER is not needed. You can use SEU both into and out of the meter into the first means of disconnect.
Old 04-27-2015, 01:21 PM   #3
DIY Expert
Rewards Points: 73
Ok, thanks. So SEU 4/0-4/0-2/0 Al should be fine for the whole run then?
Also, just to be clear, what currently is there (picture below), is SER, right?
Old 04-27-2015, 01:39 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
I would say that is not cable but individual conductors.
If your service is run in conduit, you should use individual conductors instead of SE cable
Coastal South Carolina
Old 04-27-2015, 02:09 PM   #5
DIY Expert
Rewards Points: 73
OK. So I could do 3x runs of 4/0 Al XHHW or 2/0 copper THHN/THWN for that section then.
Old 04-27-2015, 02:12 PM   #6
A "Handy Husband"
rjniles's Avatar
The Al will be way cheaper.
Old 04-27-2015, 06:18 PM   #7
Rewards Points: 1,989
I would not run aluminum on a bet . And I know how to terminate it .
I would absolutely not recommend a DIY'er use it .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 04-27-2015, 06:46 PM   #8
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
God bless
Wyr
Why not? That size into a new meter pan, penetrox and tighten set screw. Not the same as inside the house. IMHO
Tens of thousands of aluminum connections into UG pull sections here. Extremely rare to have an issue.
clw1963 is offline   Reply With Quote
Old 04-27-2015, 07:22 PM   #9
A "Handy Husband"
rjniles's Avatar
God bless
Wyr
Your comment just scares people for no valid reason. Absolutely nothing wrong with Al in this application.
The Following 3 Users Say Thank You to rjniles For This Useful Post:
jbfan (04-27-2015), Jim Port (04-27-2015), nap (04-27-2015)
Old 04-27-2015, 08:14 PM   #10
Aluminum feeders and service cables are installed and used safely everyday. I would not hesitate to have it in my house or to install it.
Old 04-27-2015, 08:25 PM   #11
Rewards Points: 3,396
If I put in pipe I would use copper.
No pipe se al.
( though agreed nothing wrong with al in pipe )
ritelec is offline   Reply With Quote
Old 04-27-2015, 08:34 PM   #12
A "Handy Husband"
rjniles's Avatar
No pipe se al.
What does " No pipe se al." mean?
Old 04-27-2015, 08:41 PM   #13
If I didn't pipe I would use seu and ser AL
And actually. I have piped and used AL.
Old 04-27-2015, 08:46 PM   #14
A "Handy Husband"
rjniles's Avatar
I am still mystified by your comments. What is your objection to Al in pipe (conduit)?
Old 04-27-2015, 09:14 PM   #15
Don't be mystified.
There's nothing wrong with aluminum in conduit. Nothing at all.
But.
If I take the time and energy to install conduit I like to see copper in it is all
Again. Nothing wrong with aluminum.
meter & main service panel upgrade from 100amp to 200amp CapeCod153 Electrical 2 03-26-2013 07:23 AM
Questions regarding 100amp service and panel upgrade asledge Electrical 38 12-12-2012 11:57 PM
Upgrade to 200amp service? twalber Electrical 3 07-29-2011 06:41 PM
DIY 200A main service upgrade? Philip_Soldat Electrical 54 09-07-2008 11:02 AM
Is Power cheaper with 200A Service? Dave-Denver Electrical 19 08-26-2008 11:45 PM
