200A Panel For A 6200 SqFt Home? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 06:15 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Originally Posted by stickboy1375 View Post
With out a load calculation I'm not even going to comment, but i seriously doubt a 200 amp service would suffice...
We have done this long enough to know without doing a LC that when a house reaches a certain size, we go up on the service.
A 6200 sf house just screams 400 amps or better.
Old 03-21-2013, 06:18 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
True enough, I was kind of aiming for what the actual service should have been, i've never done a house quite that big, usually smaller, but still loaded with some pretty neat toys...
Old 03-21-2013, 06:53 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
It's the pool and hot tub that are going to push you over.
Assuming you use modern lighting (led and fluorescent), 200A is fine.....but the pool and hot tub? Those could almost dictate their own 200A panel unless you go gas heating with those as well.
Old 03-21-2013, 10:59 PM   #19
" Euro " electrician
frenchelectrican's Avatar
Few years back I have done one house with 6500 sq feet size in Wisconsin and that service size if not use the pool and spa the 320 class service will hold up ok ( basically a 400 amp resdentail with 2 X 200 amp panels ) but once you get the pool and spa on ., Don't be suprised that can kick up to 600 amp service.
But the kicker is optinal generator that answer will really varies a bit. ( depending on if ya use MTS or ATS or whole panel ATS )
In France I know I did service one house with that big I think about 6800 sq feet and that used three phase service oringally they did use 160 amp service but the owner smoked the 160 amp service so end up put in 320 amp service in there. ( BTW the voltage is 415Y240 volts )
Merci,
Marc
Old 03-22-2013, 12:18 AM   #20
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Unless it's all electric heat I would not really worry about it. Though for a house that size I'm surprised there's not a couple sub panels around to make running wires easier. If you do need more room that's always an option.
Old 03-22-2013, 06:08 AM   #21
Originally Posted by ClemsonJeeper View Post
I'm currently about to close on a new construction home with approximately 6200 finished square feet (including fully finished basement). I am going to head over today to get actual model numbers of all the equipment, but it is two zone AC with a 75 gallon water tank (gas). It has a gas cooktop, convection microwave oven with a dual oven underneath it. There are two dishwashers, one large fridge, one mini fridge, and a washer/dryer. Each room is pre-wired for ceiling fans and there are tons and tons of outlets and recessed lights throughout.
thanks!
Not sure if it changes anything but isnt a "6200 sq ft (including bsmt) "
really only a 3100sq ft house.
The basement does not count when you measure sq footage, at least not around here.
creeper is offline   Reply With Quote
Old 03-22-2013, 06:15 AM   #22
kbsparky's Avatar
Basement DOES count when it is finished ....
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Speedy Petey (03-22-2013)
Old 03-22-2013, 06:20 AM   #23
Ok for electrical purposes but not in real estate terms
I'm just saying call it what it is ..
A 3200 sq ft home with a finished basement
Old 03-22-2013, 06:23 AM   #24
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Habitable rooms are habitable rooms. WHY does it matter where they are???
A finished basement IS living space.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
kbsparky (03-22-2013)
Old 03-22-2013, 06:28 AM   #25
It doesn't matter to me personally what the op wants to say. However, he is giving the impression of some enormous mansion when in fact the house is only half the size.
Why are you so bent on defending it
Old 03-22-2013, 09:35 AM   #26
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
If it is a two story house with a 2000 sq ft foot print then that leaves 4000 sq ft for the upper two floors. That is a big house. My house is 2400 sq ft with a 400A UG service. If I did again it would be a 200A with six 100A panels/disconnects.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-22-2013, 11:20 AM   #27
I call anywhere I can stick a box (storage) or a room I can sit in and do something part of the square footage. But if the seller does not count that in the price, that is fine with me!
Billy_Bob is offline   Reply With Quote
Old 03-22-2013, 11:31 AM   #28
He can call it Buckingham Palace as far as I'm concerned, but lets face it you all envisioned an enormous house. But there is a reason for clarification.
If this place was a 6200 sq ft bungalow for a total of 12,400 or even a two story that had 3100 on each floor that still leaves 3000 sq ft of finished bsmt that should be accounted for in the electrial panel.
This changes things don't you agree, as far as power requirements are concerned.
Old 03-22-2013, 11:35 AM   #29
jbfan's Avatar
Rewards Points: 490
Square footage here is counted as heated space.
That house could be listed as 3100 square foot /w unfinished basement, or listed as 6200 square foot including basement.
Old 03-22-2013, 11:40 AM   #30
In Ontario if you listed a house for sale as a 6200 sq ft house including a finished basement, then you are in violation of MLS and OREA (Ontario Real Estate Council) rules.
You have to list it as a 3100 sq ft home PLUS finished basement as extra living space.
You'd never find a real estate agent that would agree to it, They'd be sued
FPE Panel change out. Main Breaber to Lug TJ14u Electrical 4 01-22-2013 10:54 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Mounting 200a semi flush panel in stucco socalsteve72 Electrical 5 03-10-2012 01:50 PM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
