2001 Jacuzzi Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 12:25 AM   #1
2001 jacuzzi wiring
I have an older Jacuzzi j-365 spa, I have run a new hard line 220 with a 50 amp breaker at the service panel of the house and at the spa I have a gfi with a 50 amp breaker, my problem is the spa is only a three wire and the gfi has the fourth wire which is the neutral there is no place to connect the neutral wire in the spa, I had it all done by electrical contractors is there a way to put a neutral wire ( fourth wire ) to a three wire spa, I was told I needed the gfi for code and safety, so can anyone help, please
hotrod32 is offline   Reply With Quote
Old 03-27-2013, 12:30 AM   #2
" Euro " electrician
frenchelectrican's Avatar
You will need the netural at the GFCI breaker to get the GFCI function properly if you do not use the line netural it will not function at all.
So therefore you will need the netural to get the GFCI working after that the load side if your spa is strictaly 240 volt loads without netural that is not a issue it will still work with straight 240 volt load.
Merci,
Marc
Old 03-27-2013, 08:35 AM   #3
Rewards Points: 309
Can you install the GFI breaker at the service panel? That is where mine is located. You must have the neutral hooked up for the breaker to function. Worst case is a new GFI two pole breaker for your panel if the one outside is not compatible with your panel brand.
al_smelter is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
