2000' Underground To House? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 11:17 AM   #16
Semi-Pro Electro-Geek
Rewards Points: 2,922
Originally Posted by AllanJ View Post
I must be missing something. I never thought that putting in a transformer halfway had any benefit unless you needed to tap off at that point. I always thought it was better to put the step up transformer at the start of the run and the step down transformer at the end.
The longer the high voltage portion of the run, the less energy lost in voltage drop given the number of amperes needed at the final voltage.
Isn't 600 volts hot to ground and 1200 volts hot to hot classified as a 1200 volt system? An aside: the voltage rating of a 3 phase system is the voltage from phase to phase.
You're right. Article 300 uses nominal voltage, not voltage to ground, to define the insulation class required. So much for that idea!
mpoulton is offline   Reply With Quote
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
