200 Amp Service Panel Location Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 08:51 AM   #1
200 amp service panel location question
I am installing my new service panel in my pole building on a wall toward the front. It is in a location where the 12'X12' garage door still retracts over it. It is in a 40 X 48 enclosed pole building. The retracted door is still a good 5' from the top of the service panel. The service wires come in to the bottom of the service panel. Would this location potentially be a problem for the inspector? No one advising me on the job has said this was an issue but I just noticed it after I has the doors put in.
stevo1213 is offline   Reply With Quote
Old 10-27-2011, 08:55 AM   #2
Rewards Points: 6,652
I would place the panel on another wall. You do not need someone opening the door, while someone else is working on the panel.
Old 10-27-2011, 10:55 AM   #3
your kinda in a gray area in the code. It says you need 3ft clearance in front of the panel to allow access for workers. But the door isnt permanently in front of the panel either, so Id just go with your gut on this one. Gregzoll mentioned the only real problem with setup.
socketman is offline   Reply With Quote
Old 10-27-2011, 11:59 AM   #4
liscenced electrician
Rewards Points: 538
it will be entirely up to the AHJ. Your going to have to check with the inspector. Nobody else will be able to give you any answer other than "my inspector would (or wouldn't) except it"
Although maybe a picture would help, because im not sure i follow you 100%. Does the door pull open to the side, and if you pull it all the way open it blocks the panel?
jimmy21 is offline   Reply With Quote
Old 10-27-2011, 12:04 PM   #5
Licensed electrician
Rewards Points: 1,738
Sounds like this is a rollup door that when up is 5' over the top of the panel. Without a better picture I don't see an issue.
Old 10-27-2011, 12:07 PM   #6
Rewards Points: 538
thats where im confused. How would a roll up door cover a panel when open, but not closed. Unless the panel is mounted in the ceiling. I guess im just a little lost on this one
Old 10-27-2011, 12:19 PM   #7
My electric company has a document on their web site called "electric service requirements". But I don't remember seeing anything about garage doors in that? Anyway your electric company should have something similar. This will say what you can/can't do with an electric service.
FYI - In my area, you are required to have a main disconnect outside, perhaps why they don't mention anything about inside doors?
Including and beyond the electric service, it is the local inspector's sayso...
Billy_Bob is offline   Reply With Quote
Old 10-27-2011, 02:27 PM   #8
My impression is that the panel is mounted on a side wall and the door when opened extends into the air space 5' above the panel.
Old 10-27-2011, 02:32 PM   #9
Rewards Points: 538
if thats the case then no AHJ would ever have a problem with it. If thats the case
Old 10-27-2011, 03:50 PM   #10
Sparky
Rewards Points: 510
violation.. yes.
likely to be noticed, no.
Techy is offline   Reply With Quote
Old 10-27-2011, 04:03 PM   #11
Techy, the door might not be over the footprint of the panel. It might just extend over the required workspace tho.
I wish the OP would clarify.
Upgrading Service/Moving Panel TheAcademician Electrical 17 09-13-2011 07:48 PM
Service move - old panel, separating neutral and ground WillK Electrical 3 06-17-2011 08:18 AM
Sub panel clearance question Red Squirrel Electrical 2 05-09-2011 09:53 PM
Service Panel Basic Questions Monkey100 Electrical 14 11-13-2008 04:55 AM
new service panel The Barber Electrical 1 05-16-2008 05:49 PM
