200 Amp Service Enough? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 02:00 PM   #1
200 amp service enough?
we have added on to our house and now im wondering if it will be enough.
We are all electric. it is 2150 sq. ft. , 3 bedrooms, theater room, 2 bath.
do i multiply 200 amp by 240 or 220 to get my total allowable wattage?
then take 80% of that right?
thanks
rustic is offline   Reply With Quote
Old 01-08-2009, 04:10 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 256
Try this site.
http://www.electricalknowledge.com/SFDLoadCalc.asp
jbfan is online now   Reply With Quote
Old 01-08-2009, 08:16 PM   #3
thanks.
if it does appear that i will need more juice, i have thought of a solution. let me know what you think about it.
I have a shop that has its own 200 amp service. It is behind my house about 100 ft away.
Could i run a 6/3 cable with ground that is underground rated and in conduit from my shop to power my central air unit?
Old 01-08-2009, 10:28 PM   #4
Rewards Points: 150
I doubt you are over loaded. I would make sure your loads are balanced on your main panel.
Can you post what all you have on your service?
Gary
Gary_602z is offline   Reply With Quote
Old 01-08-2009, 10:30 PM   #5
Electrician
Gary
A load calc is the only way to know if the service is large enough, this requires knowledge of Art. 220 of the NEC.
chris75 is offline   Reply With Quote
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
How can I determine service amperage? dawho1 Electrical 13 04-07-2008 11:10 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
