200 Amp Service - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 06:35 PM   #16
I don't care how young or poor you are, it's no excuse to do schitty work. Do not install a 3 phase panel on a single phase service.
If the panel is new, some contractor would trade you in a heartbeat.
220/221 is offline   Reply With Quote
Old 04-02-2009, 01:53 PM   #17
Wouldn't
I wouldn't install it that's for sure.
You got a speeling problem????
SULTINI is offline   Reply With Quote
Old 04-02-2009, 03:04 PM   #18
did you ever throw snowballs at santa?
NolaTigaBait is offline   Reply With Quote
Old 04-02-2009, 04:15 PM   #19
Yeah, and how ya' doin' otherwise, Mr. S?
http://en.wikipedia.org/wiki/Global_...of_Functioning
Old 04-02-2009, 05:45 PM   #20
Knot Baaaaaaaaaaaaaaaaaaaaaaaaaaaaaaad
Old 04-03-2009, 10:16 AM   #21
Glad to hear it. So you're at 91-100??
Old 04-07-2009, 05:56 AM   #22
new panel
Ok I got a new panel, new meter socket and a 200 amp breaker at the meter socket. I just want to be sure about a couple of things. The main electric is on a pole going down to the meter, then out to the 200 amp breaker. This was done with 4 awg AL and a neutral, all incased. Is this correct? Then from the breaker to the new 200 amp panel ( 100' run underground ) I used three 4 awg AL and one 2 awg AL. Using the 2 awg AL as the ground and the third 4 awg as the neutral. Is this correct? I have disconnected the ground bar in the panel on the right of the panel so that the ground goes to the right bar and the neutral goes to the left bar. Is this correct and not trying to sound stupid here but why? All the house panels I have connected you run your ground and neutrals to the same bar. Just trying to make sure the job is done right. Thanks
Brian0075 is offline   Reply With Quote
Old 04-07-2009, 06:22 AM   #23
Electrical Contractor
jbfan's Avatar
Rewards Points: 466
I hope you mean 4/ought wire and not #4 wire.
jbfan is online now   Reply With Quote
Old 04-07-2009, 06:38 AM   #24
Yes 4 ought Aliumium
Old 04-07-2009, 02:45 PM   #25
just happened to have something you could use SAFELY and it would improve your property
How is hacking up your electrical system going to improve your property?
I'm glad you did it right Brian
To clarify, the neutrals and grounds are separated after the first disconnect. Sometimes the first disconnect is at the panel in the house.
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
How can I determine service amperage? dawho1 Electrical 13 04-07-2008 10:10 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
