200 Amp Service - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2009, 04:44 PM   #1
200 amp service
I have a new 200 amp service. I have a 200 amp three phase panel. The new service is not three phase. Can I hook up the 200 amp two phase service to a 200 amp three phase panel? Would I use the the two outer poles of the 200 amp three phase main breaker? Thanks
Brian0075 is offline   Reply With Quote
Old 03-31-2009, 04:52 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
You could but why??? You will be losing 1/3 of your panel space.
Just get a single phase panel.
Old 03-31-2009, 05:20 PM   #3
trying to cut money I understand what you are saying, but the panel has plenty of space. Am I right on how it is hooked up though? Thanks for the reply.
Old 03-31-2009, 06:25 PM   #4
i guess it wouldn't matter which pole you hook kit up on....you'll lose 1/3 of your spaces, just as Petey said....but WHY??????...you are saving what.....150 bucks
NolaTigaBait is offline   Reply With Quote
Old 03-31-2009, 06:48 PM   #5
why??????
Because he already has the panel. Some people don't have 150.00 but have the material.
Times are tough.
SULTINI is offline   Reply With Quote
Old 03-31-2009, 06:58 PM   #6
Sorry sultini. Some of us want to do the right thing regardless of $150.
I'd rather not do the job than hack it up for $100 savings.
If you can't afford the material don't do the job.
Old 03-31-2009, 07:36 PM   #7
I'd rather not do the job that hack it up for $100 savings.
Old 03-31-2009, 09:26 PM   #8
Idiot Emeritus
Rewards Points: 1,492
I agree with Petey as well; do it right the first time.
If you use two of the phases of a 3 phase panel, sooner or later someone is going to install a breaker into one of the dead slots. Their solution will almost certainly be to jumper the dead phase to one of the hot ones. The net result will be;
A) An overloaded neutral on a multi-wire branch circuit. The chances of this causing a burn-up or even worse, a fire, is actually pretty good. Not worth the risk.
B) A lot of current on the service neutral. If the service is underground, the POCO neutral is likely two sizes smaller than the hots. It isn't designed to carry lots of current for extended periods of time. If it burns up, roughly 1/2 of the equipment in the building will be destroyed. If the POCO finds out you have a 3 phase panel connected to a single phase service (they will, believe me!), they will refuse to pay for any damage.
Can you get just the interior for your panel? Most panels have the same mounting for both single and 3 phase interiors.
If not, I'd get the single phase panel, even though it would be an extra cost.
Rob
micromind is offline   Reply With Quote
Old 03-31-2009, 09:33 PM   #9
FWIW, I believe it's single phase, center tapped, because the only phase shift that's available is zero degrees or 180 degrees.
Old 04-01-2009, 08:06 AM   #10
Agreed with brian0075
I agree the job should be done right and SAFE the first time, However all you folks agreed with Brian 0075 in the posts that what he requested he could use now your all jumping on me for a minor comment.
Let me take you all back to when you were real young and just starting out with 0 money but you wanted to improve your life and just happened to have something you could use SAFELY and it would improve your property. You used it don't deny it. You know you did get back to reality and common sense safely.
If he couldn't use it you should have said so right off the bat but you all stated he could.
Old 04-01-2009, 08:39 AM   #11
Sorry, this is not a court of law. It is not as black and white as you want to make it out to be.
Old 04-01-2009, 10:05 AM   #12
Thanks for the advice. I do understand about lossing 1/3 of the panel just trying to save a little. It is hard times and trying to improve. But I see what you are saying, Thanks.
Old 04-01-2009, 10:45 AM   #13
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
The way I read things.. all that was said is that.. " if ".. you know what your doing it could be done but I also read it wouldn't be safe. Simply answering his question. I do not see one comment that says to use that 3 phase panel.
So let me say this to Brian...."If you use that three phase panel put your stupid hat on"......
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 04-01-2009, 01:28 PM   #14
Why do you think that is happening?
Old 04-01-2009, 02:56 PM   #15
Credit card
What's up with this credit card bologna????????????
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
How can I determine service amperage? dawho1 Electrical 13 04-07-2008 11:10 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
