Old 07-26-2007, 08:49 PM   #1
200 amp panel with a 100 amp service?
Hello all. This is kinda of follow up to a previous post. My situation: I have 100 amp service with a 100 amp fuse box. I'm totally renovating the kitchen and need extra space for more circuits. I have a small house (830 sq ft) with gas heat, central A/C, electric water heater, electric clothes drier and a washing machine. I plan to add a microwave over the range, a DW and food disposer.
I feel that 200A is overkill for a house this size. But if I'm going to spend about $600-$700 on having a breaker box with ANY amp rating put in, then it'd be nice to know that I can upgrade later upgrade the service to 200, if ever really needed, and not have to install a new 200A box for it. All the work that would need to be done at that point would be upgrading the drop, service wiring and meter box.
I do realize that I can't attempt to draw more than 100 amps into my house with my current service wires and that's not what I want to do. But someone in my previous thread suggested I try to get 150 amp service and run it to a 200 amp box with a 150 amp main breaker. My electrician told me that he'd have to redo the entire service if I want 150A and said it would therefore be just as expensive as getting 200A. So the big question: is it possible to legally and safely put a 100A main breaker in a 200A box? And then run it with 100A service? Then my panel would be ready for 200A service if I ever really need it, which I seriously doubt that I will.
Why not just do 200A everything right now? It'll cost me twice as much and I could use that money on nicer counter tops!
alexz is offline   Reply With Quote
Old 07-26-2007, 09:39 PM   #2
Electrician
Hey there
One question you should ask yourself, is there ever a chance of you putting in electric heat as your main heating source. If the answer is an absoulety no then all you need is a 100A service. If there is a chance you may consider going electric heat you should upgrade to a 200A.
My house is 1100SF have the same thing as you except my hot water tank is gas. I beleive my panel is fused at 70A and I have had no problems in the 3 yrs i have been here.
If all you need is more circuits why not keep it simple and add a subpanel for your new circuits. Will be alot cheaper then a new service.
darren is offline   Reply With Quote
Old 07-26-2007, 09:43 PM   #3
Electrical Contractor
The electrician needs to do a load calclulation and see if the house needs to be upgraded. It may be that you just need a larger panel with more spaces, and not more current.
You cannot put a 200 amp main breaker panel on a 100 amp service, unless the service is protected at 100 amps.
I would not even entertain that as an idea.
How many slots are in your panel now?
Just because you need more space, does not mean you need to upgrade to 200 amps.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 07-26-2007, 10:03 PM   #4
Thanks for replying so quickly. Very appreciated. The electrician agreed that I wont need more than 100A after my kitchen upgrades (the addition of a microwave over the range, DW, and disposer isn't going to add that much). If my gas heater ever dies, then I'll be going to electric heat pump and I understand that I will need 200A at that time. And there's a slight chance that I might do an addition to this house in 6-8 years if real estate gets out of control and it's cheaper than buying a larger house ... very slim chance. My current fuse box is totally full - I can't add a single circuit and I need 3 more the kitchen alone and I plan on rewiring the lighting and bedrooms down the road.
Why not use a sub-panel? I want to get off of the fuses all together. That box is old and will hurt the resale value.
How could you protect the service at 100 amps? Put some sort of switch/breaker/fuse between the meter and the panel? That legal? Why would you not even entertain that as an idea? If you need the circuit spaces, but don't need the amps, but want to keep your 200A option open in the future, why not? Yeah, I know I can get a 100 amp panel with 30 spaces, but why not be ready for 200A service if I MIGHT need it down the road? It'll cost me twice as much to upgrade everything to 200A. Also, spending the money on installing a 100A box would be wasted if that 200A need ever comes.
Old 07-26-2007, 10:15 PM   #5
Yes you would have to change the meter and add a 100 amp breaker outside.
If you are going to go thru that much trouble, you might as well upgrade the whole system then.
Right now the incoming wires are protected by the 100 amp fuses in the fusebox. If you change the fusebox to a 200 amp panel, then the wires will be protected by the 200 amp breaker, and they would be undesized.
Old 07-26-2007, 10:22 PM   #6
.... will upgrade the entire service. But I think I found a pretty good deal!
AZ
Old 07-28-2007, 12:56 AM   #7
retired
Why not use a 200 amp rated panel with a 100 amp main breaker? If he can't install a 100a main in place of the 200a main, he could buy a 200a main lug panel, plug in a 100a breaker, and back feed through it. Just because the panel is rated for 200 amps doesn't mean you have to have a 200 amp main in it. Right?
dmaceld is offline   Reply With Quote
Old 07-28-2007, 10:22 AM   #8
If he wanted to, he could.
Old 07-28-2007, 01:30 PM   #9
He could do anything he wanted
HiFi is offline   Reply With Quote
Old 07-28-2007, 09:36 PM   #10
Master Electrician
JohnJ0906's Avatar
Check your electric bill for the last year or 2 to see what the average useages are. This will give you an idea of how close to the 100 amps you are using now. You can also get this from your power company, if it is not on your bill.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 07-29-2007, 11:00 PM   #11
can you tell me how to do that load calculation using a few years of electric bills
coyote556 is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Main Service Panel Full bobo Electrical 5 09-24-2007 08:13 PM
meter to service panel mikim Electrical 5 05-04-2007 06:34 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
Basement receptacle under service panel mekanic Electrical 2 05-12-2006 06:41 AM
