200 Amp Meter Loop Critique My Work - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 07:19 PM   #1
Rewards Points: 152
200 amp meter loop critique my work
I installed my 200 amp service main today and am posting here for critique. I have to call for an inspection and want to make sure all is well.
I had an old mast with 3/0 THWN wire, so I used that from the head to the meter can. I bought 5' of 3/0 wire to make the run from the can to the main breaker. My ground wire is #4 and run in conduit out the bottom of the meter can. AEP only requires one ground rod.
200 amp meter loop critique my work-meter-loop-003.jpg   200 amp meter loop critique my work-meter-loop-001.jpg   200 amp meter loop critique my work-meter-loop-002.jpg   200 amp meter loop critique my work-meter-loop-005.jpg
n175h is offline   Reply With Quote
Old 11-26-2012, 07:22 PM   #2
Rewards Points: 152
One thing that bugs me is I have the bottom of the mast standing off the pole 3/4" and flush against the pole at the top, so it has daylight between it and the pole at the bottom. Any chance of getting gigged on that?
You can't see it very well in the picture, but the POCO transformer is on the pole behind mine in the picture. It's about 10' from my pole. My service mast is about 15' above grade.
200 amp meter loop critique my work-meter-loop-006.jpg   200 amp meter loop critique my work-meter-loop-007.jpg
Old 11-26-2012, 07:24 PM   #3
TTW
TTW's Avatar
I don't see a ground wire from the meter base to the disconnect panel, maybe it just doesn't show in the pic. Besides that looks good to me!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 11-26-2012, 07:24 PM   #4
Rewards Points: 152
Neutral is taped white at both ends. Ground it taped green at both ends. Bonding jumper is connected.
Old 11-26-2012, 07:26 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Is that a metal or PVC offset nipple?
Old 11-26-2012, 07:36 PM   #6
k_buz's Avatar
You wouldn't need a separate ground.
Old 11-26-2012, 07:59 PM   #7
Master Electrician
Rewards Points: 3,678
That panel needs a hub or sealing washer. Is the lower end of the emt with the ground wire bonded on the lower end?
brric is online now   Reply With Quote
Old 11-26-2012, 07:59 PM   #8
Rewards Points: 152
Metal Offset.
I needed as much offset available to get the 1/2" EMT to pass behind the panel. I guess I should have used flex, but I had the EMT in my store room, handy, so I grabbed it and used it.
BTW: The wire in the pipe is 3/0 CU. Ground wire is #4
Old 11-26-2012, 08:03 PM   #9
Rewards Points: 152
Darn, missed the sealing washer, but I don't think our local electricians ever use one. I'll drive out to a new subdivision tomorrow and look.
No, the lower end is not bonded. I've never seen that done anywhere in our jurisdiction. The electricians just pass it through the pipe end and clamp the wire to the rod.
Old 11-26-2012, 08:06 PM   #10
Rewards Points: 152
I just remembered. The top of the panel under the offset nipple has a beveled edge upward. Would that suffice for a raintite seal sans the sealing washer? Same configuration on top of the meter can, also.
Old 11-26-2012, 08:13 PM   #11
Rewards Points: 152
I also hooked up a GFCI circuit
200 amp meter loop critique my work-meter-loop-004.jpg   200 amp meter loop critique my work-meter-loop-008.jpg
Old 11-26-2012, 08:13 PM   #12
Master Electrician
Needs a hub.
Old 11-26-2012, 08:25 PM   #13
k_buz's Avatar
Also need a bonding bushing in the meter socket.
The Following User Says Thank You to k_buz For This Useful Post:
brric (11-26-2012)
Old 11-26-2012, 08:50 PM   #14
TTW
TTW's Avatar
Would these work for you, not sure if they are just for metallic conduit or ok for pvc.
Old 11-26-2012, 09:38 PM   #15
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The metal raceway containing the ground wire needs to be bonded at both ends or change raceway to PVC. Meyers hub on top of the panel. Grounding bushing for offset nipple.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
stickboy1375 (11-27-2012)
Can homeowner (or friend) rewire in California? cvandewater Electrical 34 01-14-2012 01:04 PM
Insulated metal grounding bushing in meter socket WillK Electrical 7 05-26-2011 10:10 AM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 11:07 AM
How does electricity meter calculate kwh? deerhunter Off Topic 18 09-06-2010 09:26 AM
Duct work in garage. flashme18 HVAC 1 11-08-2009 07:29 PM
