200 Amp Meter Base Hook Up - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 06:51 PM   #1
200 amp meter base hook up
black arrows are black wires and white arrow are white wire.. is this set up correct ??
chessy is offline   Reply With Quote
Old 06-16-2012, 09:43 PM   #2
Master Electrician
Rewards Points: 3,762
My guess is that your neutral connects to the hexagonal lug at the left of your white arrow, leaving the other point for the POCO.
brric is online now   Reply With Quote
Old 06-16-2012, 10:22 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I think your hots are correctly labeled, but the white should go to the lug to the left of where your white arrow is.
The POCO will probably use crimp connectors that bolt down where your white arrow is.
Old 06-16-2012, 11:19 PM   #4
thanks guys .. yes arrow a little off.. it went into the lug thanks for the info ...
Old 06-17-2012, 02:56 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You may have to supply the lugs for the power company....
Old 06-17-2012, 03:02 AM   #6
" Euro " electrician
frenchelectrican's Avatar
Yep I know few POCO will ask the customer to provide the lugs but most case the POCO will have them in thier truck unless got a oddball size there.
The other thing this part will get your attetion is the Belleviue washer ( SP ) ya denfinely need a toqure wrench on that one.
Merci,
Marc
Old 06-17-2012, 03:05 AM   #7
opps., Désolé
Old 06-17-2012, 09:51 AM   #8
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Here we have to have all our lugs crimped on and connected before inspection.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-17-2012, 09:53 AM   #9
E2 Electrician
We are required to use by-pass handles in all residential meters...
Can the meter socket itself be replaced? Johnd85053 Electrical 19 02-14-2012 07:02 AM
Bathroom project: in floor heating, slc and shower base Me xeno Flooring 1 01-20-2012 08:12 AM
do I need a meter main? 1dumbquestion Electrical 11 12-17-2011 09:05 PM
how to nail base cap of baseboard molding conradA Flooring 3 06-23-2010 12:57 PM
