200 Amp Main To 200 Amp Sub? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 09:15 PM   #1
Question
200 amp main to 200 amp sub?
I'm in the process of educating myself as well as draw up an electrical plan for a shop I'm in the process of ordering.
Where the shop is going I have a 200 amp Service panel that went with a Mobile home that has been removed and I plan to use that service panel to power my shop.
I also have a new Square D QO 200 amp panel that I would like to use in the shop as a sub panel.
Everything that I've found so far covers a lower amperage panels as the sub coming off the Service panel with a breaker rated the same as the Sub Panel which makes since.
Is there a way to connect the 200 amp sub to a 200 amp service panel or does sub have to be less amperage then the service panel?
CaptainD51 is offline   Reply With Quote
Old 11-22-2011, 10:13 PM   #2
Electrical Contractor
kbsparky's Avatar
Use feeder cables rated for 200 Amps, and it should be fine.
Got any pics of your "service panel" available?
-KB
Old 11-22-2011, 11:07 PM   #3
I can get them in a few days when I make it home.
It is a GE panel and the bottom of the bus has lugs. One of the things I was looking into was if I could run 3/0 THWN from the lugs and have the service disconnect / Breaker protect the run. (The run will be about 60 feet to the new panel.)
Old 11-22-2011, 11:13 PM   #4
kbsparky's Avatar
Yup. Works for me.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
CaptainD51 (11-23-2011)
Old 11-23-2011, 03:40 PM   #5
you can use the feed through lugs in the bottom of the disconnect/outside panel and you can also down grade your neutral to a 2/0 if your going to have lot of computors in the new building then run a 3/0 neutral.
epsllc is offline   Reply With Quote
The Following User Says Thank You to epsllc For This Useful Post:
Old 11-23-2011, 05:20 PM   #6
I was hoping I could do that.
Thanks to both of you for the reply.
Old 11-23-2011, 05:32 PM   #7
almost forgot if you use 3/0 it must be in copper if your going to use alum then you must use 4/0
Old 11-23-2011, 05:55 PM   #8
Master Electrician
Rewards Points: 3,864
IMO the shop is a separate structure and would need a main disconnect.
brric is offline   Reply With Quote
Old 11-25-2011, 11:51 AM   #9
Here is the GE main panel and the QO sub panel. The GE main panel has two "Service Disconnects" One is the main disconnect and the other goes to a small panel that I will probably be removing. (Upper right)
I assume you are refering to the main breaker in the sub panel?
Old 11-25-2011, 11:59 AM   #10
Master Electrician
Use a four wire feeder, add an equipment grounding bar, do not bond the neutral to the can,, add ground rods and that QO will work just fine.
Old 11-25-2011, 12:11 PM   #11
I was planning on using a #5 rebar in the footing for a "CEE".
From my unserstanding, you would use a "Bug" (copper clamp to the rebar that sits a few inches off the bottom of the footing.) (Got this from reading on grounding techniques.)
My question for that would be, do I spec a solid copper # 4 or larger conductor that is attached to the rebar and then runs up next to the conduit that goes to the panel?
That is one of the details I've been unable to find.
Old 11-25-2011, 12:40 PM   #12
Master Electrician
#4 bare or insulated. We have been noticing that thhn is cheaper than bare copper.
The Following User Says Thank You to brric For This Useful Post:
CaptainD51 (11-25-2011)
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 07:28 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
