200 Amp Line? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2010, 08:49 PM   #1
200 Amp line?
Can you tell if this cable is OK for 200 amp service?
ftp://cj136.gotdns.com/files/DSCN8069.JPG
CJMEDINA is offline   Reply With Quote
Old 02-09-2010, 09:10 PM   #2
Which cable ?
The cable (ind wire maybe too) will be labeled with an AWG number - that tells us how much power it can handle
Black & Red main hots looks like they are labeled ALUM
Old 02-09-2010, 09:13 PM   #3
The Main Wires RED and Black
Old 02-09-2010, 09:15 PM   #4
Rewards Points: 266
Not a chance.
Looks like a #2 AL to me.
junkcollector is offline   Reply With Quote
Old 02-09-2010, 09:15 PM   #5
You need to read the lettering on the wire
Old 02-09-2010, 09:19 PM   #6
Yes I see it says ALUM which means?
Old 02-09-2010, 09:23 PM   #7
Originally Posted by junkcollector View Post
Not a chance.
ALUM wire...means prob too small
It should have a number
But as Junk said it looks too small
Old 02-09-2010, 09:36 PM   #8
Idiot Emeritus
Rewards Points: 1,492
A 200 amp aluminum wire will be at least a 4/0. A 4/0 is around 3/4" in diameter.
I agree with the above, the black and red look like a #2. A #2 AL is good for 100 amps as a service entrance, 90 amps as anything else.
Rob
micromind is offline   Reply With Quote
Old 02-10-2010, 06:53 AM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Which means aluminum and has nothing to do with the size.
The others are right. You have a 100A service with conductors sized appropriately.
99.99% of the time the conductors are sized properly. Which means a service upgrade would include new, larger, service entrance conductors.
Old 02-10-2010, 12:12 PM   #10
remodeling pro
Originally Posted by Scuba_Dave View Post
Which cable ?
Just the question is scary for me, so I just will only make opinion comment.... WHY would a DIY pose a question related to 200 amp service wire.. Not trying to insult, but 200 amp service is not DIY project.
troubleseeker is offline   Reply With Quote
Old 02-10-2010, 12:57 PM   #11
I would have no problem installing a 200-400a service on my house
--as long as the POCO cut the power & then reconnected me
Old 02-10-2010, 01:24 PM   #12
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
I agree with this. Diy is not always easy peasy. It may take a lot of time and a little xp to get it done. Plus I have seen the trash work some pros do and that scares me more then what i would do.
Big N8 is offline   Reply With Quote
Old 02-10-2010, 02:11 PM   #13
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
None of the wires in that picture are good for 200 amps.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 02-10-2010, 02:48 PM   #14
Rewards Points: 502
...WHY would a DIY pose a question related to 200 amp service wire.... 200 amp service is not DIY project.
I am with Scuba.
Follow the rules and keep safety first, get the permit, and get it inspected.
Most POCOs wont reconnect power until it passes inspection.
I upgraded from 200 to 400 amp service, everything went fine.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-10-2010, 02:51 PM   #15
I will follow the rules for sure.....
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
