200 Amp Feed Through Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 03:39 PM   #1
200 amp feed through panel question
Hi, guys, this is my first post here, but i been getting good inf. from here for years.
My question Is. I'm running service entrance from 200 amp feed through panel to my house also 200 amp. Wire i use is 4/0,4/0/4/0, 2 aluminum. I'm including picture so you can see how im planning to do this. I think i'm right but just want to confirm.
https://picasaweb.google.com/lh/photo/2T7mQbVdZPdj7V388yewfqtdAJl03T2ltztnEK-DelU?feat=directlink
Thank You
ollemar is offline   Reply With Quote
Old 02-18-2012, 07:42 PM   #2
Rewards Points: 264
I'm assuming you're asking if the picture indicates the correct locations to attach the wire to for the feed through. If so, then you're good for the hots and neutral. For the ground, you need to either buy a new ground lug or confirm that the lug there allows two wires on it.
a_lost_shadow is offline   Reply With Quote
Old 02-18-2012, 07:50 PM   #3
i will put the ground whats there at the moment to the ground bar . But yes that was my question. I guess what really confused me was that ground and neutral are basically connected to each other.
Thank your answer
Old 02-18-2012, 08:06 PM   #4
Rewards Points: 264
The ground and neutral are supposed to be connected together at and only at the main service disconnect. This allows the ground to complete the circuit in the event of a ground fault, and thus trip your breakers.
Old 02-18-2012, 08:11 PM   #5
i see, thank you for your time.
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
Use FPE Panelas a feed through to new replacement panel. ElectriMan Electrical 16 08-05-2011 01:55 PM
Yet another sub panel question jboggz Electrical 4 06-19-2011 08:27 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
