200 Amp Disconnect Recommendations - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2013, 09:35 AM   #1
200 amp disconnect recommendations
Hi,
I am upgrading my service to 200 amp and I need to start with a disconnect, due to the fact my breaker panel is about 40 feet from the meter. I was looking for any recommendations on brands or models to go with or avoid. Home Depot has a GE Model # *TG4324R for $294. I do not mind paying that much if I need to, but was looking for different options.
Thanks,
Michael
mbaldwin is offline   Reply With Quote
Old 02-13-2013, 10:30 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by mbaldwin View Post
I am upgrading my service to 200 amp...
Maybe. Maybe you need to start with a new meter pan.
Start by asking which of the several meter/main combinations
that YOUR poco accepts and will connect to.
I'm a fan of Cutler Hammer and having a copper bus.
Old 02-13-2013, 11:28 AM   #3
Rewards Points: 204
Use a meter main as shown above. It is a meter, a disconnect and a load center (panel) all in one.
You can then install your new 200 amp MLO panel inside.
A meter main gives you a few slots for breakers outside too!
Old 02-13-2013, 11:37 AM   #4
Thanks,
the town will provide the meter base, and I do not want a disconnect outside.
Michael
Old 02-13-2013, 12:01 PM   #5
MarginallyQualified
...I do not want a disconnect outside
Where do you plan to mount the fused disconnect you started with?
Old 02-13-2013, 12:29 PM   #6
On the inside of the wall from the meter, as close as I can get it depending on where the wires need to exit the meter and enter the disconnect. I would like the wires to come through the back, so if the meter base, and disconnect have rear knockouts, I'll have them lined up that way.
Thanks,
Michael
Old 02-13-2013, 12:52 PM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
A main breaker trailer panel would work so you can use the feed through lugs to feed your other breaker panel with a four wire feed.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-13-2013, 01:03 PM   #8
Thanks for the suggestion. Do you happen to know a brand and model I can take a look at? I think i know what your talking about, but have not seen one before. I have seen panels with just through lugs on them, I removed several of those in my last house, but I have not seen one with a main breaker as well.
Thanks,
Michael
Old 02-13-2013, 01:12 PM   #9
rrolleston's Avatar
Search PW0816B1200TC. Last one I bought was from home depot's web page.
Old 02-13-2013, 02:31 PM   #10
thanks, looks like it will do the trick, and for much less than a dedicated fused disconnect.
I did not come across this while browsing HD's site, but the search brought it up.
Michael
Old 02-13-2013, 02:51 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
I would go to a supply house. HD or Lowes will only have one or two disconnects, if that.
A real supply house will give you more options.
Old 02-13-2013, 03:11 PM   #12
rrolleston's Avatar
Michael
I found it when I needed one and they seemed a little high at the supply house. It was over $200 at my local supply house but you could also check the local supply houses to see when they have like Speedy Petey mentioned. About the only thing I buy at the big box stores is breaker panels because they are usually cheaper and sometimes have package deals that include breakers.
Old 02-13-2013, 06:47 PM   #13
yeah, I will chekc the electrical supply store, but HD wants 105 for the panel, so that is not bad.
Thanks very much for the assistance, I'll be back with other questions, I am sure.
Old 02-14-2013, 11:45 AM   #14
Rewards Points: 204
Why are you using a disconnect inside when you could just install a breaker panel.
You would need no disconnect then.
Old 02-14-2013, 11:55 AM   #15
rrolleston's Avatar
I think since his breaker panel is 40 feet away and he needs a disconnect closer.
I was actually at lowes today since they have lower prices on breaker panels than the supply house and see they actually stock some siemens 200 amp breaker disconnects with feed though lugs. So that may be another option. But all stores are different in what they stock.
Question: Backfeeding Gen thru Pull-Out Disconnect and GFCI (with interlock kit) diyfram Electrical 7 11-02-2012 10:59 AM
Fused disconnect or unfused, motor is fed from breaker... Do It Right Electrical 17 03-19-2011 12:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 03:55 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
