200 AMP Disconnect Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2015, 05:09 AM   #1
Rewards Points: 44
200 AMP disconnect question
Does anyone know if I connect the neutral and ground bridges together and then go to the ground rods or just go from ground bridge to rods? It is a 200 amp disconncet attached the the meter with SEU wire and SER is going to the panel inside house. Pics attached below.
akajoe87 is offline   Reply With Quote
Old 12-20-2015, 08:29 AM   #2
Master Electrician
Rewards Points: 3,870
All grounding electrode conductors terminate at the disconnect neutral.
brric is offline   Reply With Quote
Old 12-20-2015, 08:42 AM   #3
Licensed electrician
Rewards Points: 1,612
There should be a bond screw in the disconnect .
Did you forget to put a backer panel behind the meter and disconnect ? What siding are you going to install?
Old 12-20-2015, 02:56 PM   #4
Rewards Points: 1,576
You would bond your neutral and ground together in the main breaker enclosure and then run four conductors to the main panel. There should be a green bonding screw or a jumper to accomplish this. Keep the neutral and ground separate in the main panel.
I would have used individual conductors between the meter and the main breaker.
The meter and the breaker box are very close together. Will the covers fit properly? Also did you use a chase nipple without locknuts in between. That nipple has to ensure ground continuity. Usually bonding bushings or bonding locknuts are used there.
I would have put bushings on the connectors and nipple.
Are you planning to put siding around the service? I think it would be better if the service was on top of the siding. Someday you may need to replace that service and you will have a hole there.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 12-20-2015, 06:42 PM   #5
Rewards Points: 44
Ok, so bond them either at the main panel or main breaker just not both?
Old 12-20-2015, 06:46 PM   #6
Rewards Points: 44
There is 3/4 advantech behind it. It is cut even with box
Old 12-20-2015, 07:13 PM   #7
The neutral to ground bond occurs in the first means of disconnect .
Old 12-20-2015, 07:21 PM   #8
Property Mgt/Maint
Rewards Points: 1,244
Whats your plan for keeping water out of the Advantech edges.
I know that it has some weather resistance, but not lifetime exposure.
I usually wrap the block with alum first or use PVC and no wrap
Yodaman is offline   Reply With Quote
Old 12-20-2015, 07:22 PM   #9
Rewards Points: 44
Ok, can I just connect the neutral and ground using 6 copper wire and anchor it to the terminals in the disconnect box?
Old 12-20-2015, 07:22 PM   #10
Rewards Points: 44
Im going to use flashing tape around it before I j channel it.
Old 12-20-2015, 07:39 PM   #11
You use the bond screw or strap that came with the disconnect .
Old 12-20-2015, 07:42 PM   #12
Property Mgt/Maint
it always irritates the crap out of me when someone comes along after I just did something and they start a sentence with "you shoulda" bla,bla,bla.
But you really should have weatherproofed the blocks prior to mounting your boxes. I don't see how taping the edges now is going to do much. IMO
location of service disconnect for generator inlet rob613 Electrical 6 02-15-2013 12:16 PM
Fused disconnect or unfused, motor is fed from breaker... Do It Right Electrical 17 03-19-2011 12:28 AM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
subpanel question Brik Electrical 2 11-30-2008 05:31 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
