200 Amp 84 Space Electrical Panels - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 09:40 PM   #1
200 amp 84 space electrical panels
where can i get a panel that is 200amps and 84 spaces?
lornemoe is offline   Reply With Quote
Old 08-30-2010, 09:44 PM   #2
" Euro " electrician
frenchelectrican's Avatar
If you are in Canada it is not a issue most electrical supply and some big box store will have it.
If you are in USA it kinda limited depending on the code cycle and state codes will allow more than 42 circuits on one load centre.
AFAIK few states allready allowed more than 42 circuits only if you are on 2008 NEC code cycle not before that.
Normally something like that big it have to be ordered from electrical supply centre or go thru Canada electrical supply.
I am not sure what the price at the moment but it will varies a bit.
Sometime it cheaper to get 2X 200 42 space panels plus just get one Power take off lugs to feed the second panel { check the code on this one }
Merci.
Marc
Old 08-30-2010, 09:53 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Here's one with 60 spaces:
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Can't seem to find one with more, but it would probably be hard to find. What I'd look into doing is maybe just getting two panels. Have one feed off the other with the highest breaker you can get, or as high as your main. That way it's sorta like being all one panel, no need to worry about overloading the sub. The main breaker will do it's job if it needs to.
Old 08-30-2010, 09:55 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
Keep in mind, even if you can find and 80 space panel it will be a 40/80, not a true 80 full spaces.
Speedy Petey is online now   Reply With Quote
Old 08-30-2010, 09:57 PM   #5
Originally Posted by Red Squirrel View Post
Huh. That is a 60/80.
HAHAHA, that sucker is over 43" tall!
I know Canada has allowed these for a while but I have never seen one, especially down here. I hope we can get them soon.
Old 08-30-2010, 10:08 PM   #6
Wire Chewer
Rewards Points: 90
Yeah I was quite surprised at the height too. I would love to see that thing. Needs a flux capacitor coming off the side with steel conduit, too.
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
how to run electrical wire with no attic space and inability to remove ceiling boards jacksondog2264 Electrical 3 07-01-2010 10:09 PM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Dedicated equipment space for subpanel? WoodworkerDave Electrical 11 09-14-2008 06:32 PM
