Old 05-30-2012, 10:22 PM   #1
200 amp
can I hook a 200 amp pannel up to a 100 amp service
boord54 is offline   Reply With Quote
Old 05-30-2012, 10:29 PM   #2
Licensed electrician
200 amp
Are you asking about feeding the 200 from the 100 or are you replacing the 100 with the 200?
If replacing you will need to install a breaker to protect the 100 amp wires.
Old 05-31-2012, 12:53 AM   #3
" Euro " electrician
frenchelectrican's Avatar
200 amp
It can be done however you will denfifly have to buy 100 amp two pole breaker to protect the 100 amp service entrance conductors or cable.
Is this used for replacement or used for subpanel that answer will change a bit.
Merci,
Marc
