Old 08-27-2012, 02:31 PM   #1
20 vs 30 AMP fuses
The fuse blew. Can I use a 30amp TL in place of the 20 amp W without causing damage? This fuse runs the refrigerator, coffee pot, toaster oven, microwave, etc.
tracer is offline   Reply With Quote
Old 08-27-2012, 02:36 PM   #2
A "Handy Husband"
rjniles's Avatar
20 vs 30 AMP fuses
NO! You have to much on this circuit. You need to run an additional circuit (or 2) and split up the load.
Increasing the fuse size can cause the wire to overheat and cause a fire.
Coastal South Carolina
Old 08-27-2012, 02:36 PM   #3
Electrical Contractor
20 vs 30 AMP fuses
No, the wire size dictates the size of the breaker or fuse.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-27-2012, 02:42 PM   #4
20 vs 30 AMP fuses
You will burn the house down.
bobelectric is offline   Reply With Quote
Old 08-27-2012, 04:49 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
20 vs 30 AMP fuses
And considering what this circuit runs a 30A circuit would NOT be allowed anyway.
Like rj said, new circuits run is the only cure.
Old 08-27-2012, 05:15 PM   #6
20 vs 30 AMP fuses
A better option would be to bite the bullet and up grade all the wiring and get rid of those old fuses.
Old 08-27-2012, 05:30 PM   #7
20 vs 30 AMP fuses
Getting rid of the fuses would not necessarily mean "upgrading all the wiring".
Fuses replaced, Circuit still dead oldcollegegal Electrical 16 08-09-2012 02:11 AM
Are fuses still used in new construction? SilveradoGuy Electrical 6 01-17-2012 06:23 PM
Replacing 240V fuses for dryer Mark77 Electrical 14 01-10-2012 10:06 PM
Heat pump wiring and fuses icandoitmyself1 HVAC 11 01-03-2012 04:56 PM
Intertherm elec furnace slowly burns 60A fuses. Goldenvoice HVAC 9 01-05-2011 11:29 AM
