20 Amp Service? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 07:49 PM   #31
JW
mm11's Avatar
Rewards Points: 592
Originally Posted by gregzoll View Post
Why, my house is up to code. If you really have this much time on your hands to be code enforcement on a Internet forum, really you need to find a different hobby, or actually work during the day like most of us do, to earn a living and pay the bills.
Wow- that really veered off on a tangent.
Give advice that is correct, and save your douche bag comments for when you actually know what you're talking about.
mm11 is online now   Reply With Quote
Old 05-28-2013, 08:15 PM   #32
Rewards Points: 6,652
You did spend a lot of time on this thread quoting stuff, that most of us already know, and really had no reason to quote what I stated, so that you could attempt to make a point with no target.
Old 05-28-2013, 08:18 PM   #33
Rewards Points: 344
Originally Posted by jbfan View Post
You have a duplex gfci, which is 2 receptacles!
Originally Posted by Kyle_in_rure View Post
A single duplex counts as two
Got it. Makes sense.
herdfan is offline   Reply With Quote
Old 05-28-2013, 08:33 PM   #34
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,318
OK... help me understand the logic..... if you have a dedcated 20 A circut serving one iindividual outlet, the requirement for a 20A configured single outlet receptical is just based on identifying, letting someone know, that that is a dedicated 20A.???
I do not see necessarily any safety consideration... I see only information to a potential user. You can still plug anything into that recep?????
But... I'm obviously missing something here.
MM.... Despite your football (EDIT ADD: mistaken) loyaltys, I for one really do very much appreciate any correction, elaboration or clarrification of things on here.... thank you.... fine points I think help us all.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-28-2013, 08:43 PM   #35
Electrical Enthusiast
Rewards Points: 504
TIA
I believe it is because you can plug any amount of appliances, up to 20 amps, in multiple receptacles. You would not want anything drawing over 15 amps plugged into any one 15 amp receptacle, However. So, a dedicated 20 amp circuit needs a 20 amp single-plex receptacle. (Hope that makes sense)
Kyle_in_rure is offline   Reply With Quote
Old 05-28-2013, 09:01 PM   #36
Kyle...thanks and sorta / almost makes sense. But I can plug in appliances totalling 2000A in my 15 or 20A circuts... albeit for a very short time.
But if I have some appliance with a 20A plug, and I am permitted to put multiple 20A recepticals on any 20A branch, I can still overload that 20A branch very easily anyway. The fact that I have a dedicated single outlet and am required to put a 20A single recep in, does not seem to be doing anything but letting me know for certain it is a 20A dedicated circut. And if I see a duplex 20A recep, I guess I say I know the circut is 20, but I better check what else is on that circut.... not pragmatically done though.
Old 05-28-2013, 09:04 PM   #37
Rewards Points: 504
I was just speaking theoretically
This is a little over my head though, just another rule I guess.
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
MTN REMODEL LLC (05-28-2013)
Old 05-28-2013, 09:27 PM   #38
DIY Enthusiast
sublime2's Avatar
Wow!
You've been here less then a month and you have already figured out a sure fire way to gain respect from your peers!
Good job!
sublime2 is offline   Reply With Quote
Old 05-28-2013, 10:00 PM   #39
Originally Posted by sublime2 View Post
Wow!
Good job!
Sublime.... I sorta understand what you were saying... but I think (guess)most of us have pretty thick skins and probably (at least me) have been called a lot worse... and if I were an inanimate object, I'm not sure it was an unfavorable insult
Regardless of how long someone has been around, and who may have started what, my respect goes to the party who was on point, correct in fact, and someone who calls a spade a spade.
Respectfully, I feel differently.
Best Peter
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
jproffer (05-29-2013)
Moving service panel away from main service line entry k2000lbs Electrical 3 11-28-2011 09:39 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
rewire and new service entrance wire dghowery Electrical 4 10-13-2010 09:31 AM
"Moving" service entrance WillK Electrical 4 09-29-2010 02:04 PM
How to tell Service amperage?? Buckley Electrical 2 06-06-2009 06:42 PM
