I everyone, new around here. Did some searches, but couldn't find an exact solution. Here's my scenario: Going to be running 12g wire from the panel with a 20 amp breaker to 3 receptacles that will be used for: my computer tower and accessories, new 55' led tv (pending wife's approval), and cablebox/ playstation. I plan on using the receptacles with built in surge protection for tv and accessories. I also need to run an exterior light and switch from this run. Here's where I need a little clarification.
I know the wire to the light and switch needs to be 12g. From reading around, I believe all lights and switches can be safely run off the 20 amp line (but I can spend more and get ones rated for 20amp if possible) - right?
Also, does it matter where I locate the light and switch along the run? Should it be first or last? I'd like to avoid dimming or any weird dips, etc that I might not be aware of, being that I will have sensitive PC and Tv equipment on it. Thanks!
