20 Amp Power Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-19-2008, 07:39 PM   #16
Plug it in your kitchen if it trips the CB then go to the garage
BillyD is offline   Reply With Quote
Old 06-20-2008, 06:24 AM   #17
When is fishing season?
CowboyAndy's Avatar
Originally Posted by BillyD View Post
Now they are picking the fly s--t out of the pepper. Common sense must be dead in America. Make your cord with romex and do your floors. You will be finished by the time you read all of these posts.
It's about following code no matter how easy and quick a shortcut may be...
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 06-20-2008, 05:41 PM   #18
Rewards Points: 150
"It's about following code no matter how easy and quick a shortcut may be..."
Sure, you can mindlessly follow some of these obscure rules to the T, but it will cost you a fortune in time and money in a house like mine. Theoretically I should have more outlets in my rooms per code. This would entail drilling through and fishing through old plaster walls and then fixing the mess later. Guess what? I ain't doing it. Instead I drop line down into what is already there. I also leave the old unconnected wire in the wall because it is stapled in there, and I would have to do major demo to take care of it "per code."
I only want that what i do to be SAFE from potential fire and other damage. That is good enough, and it is my understanding that the work is grandfathered in.
Cossack is offline   Reply With Quote
Old 06-23-2008, 06:56 AM   #19
CowboyAndy's Avatar
I have to agree, because protecting romex from physical damage and stopping movement in a solid core wire is such an obscure code...
MY HOUSE OWNS ME!
Old 06-23-2008, 07:35 AM   #20
Licensed Pro
If your house has been properly rewired, you should have 20A circuits in the kitchen, laundry, and each bathroom. Use any of those to supply your sander. Use a 12ga extension cord. If the sander has a 20Aplug, you can put together a short adapter cord for this temporary application. You don't have to go to the garage to find a 20A circuit... that is if your rewire was properly done.
Old 06-23-2008, 12:08 PM   #21
47_47's Avatar
Rewards Points: 44
Even though I saw no reason not to use the romex as an extension cord as temp power for this one job, new / replacement work is not necessarily grandfathered in and usually must conform to your current local codes. This applies to all areas (electrical, plumbing, insullation...).
What does your inspector say?
47_47 is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 05:16 PM
Power inverter AndrewL Electrical 6 03-02-2008 02:43 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
