#1 |
20 amp plug
I'm installing a whirlpool tub on a dedicated 20 amp GFI circuit. I went to hardware expecting to buy a regular 2 plug outlet but I found a round single plug 20 amp 125 volt plug. It will take a normal plug but has an extra slot running perpendicular to one of the slots. Should I use this plug?
The one I was going to buy was 2 plug 15 amp |
#2 |
Custom Cabinet Maker
20 amp plug
I probably would use a 20 double ( duplex) outlet. My thoughts are just in case you have to get under it to work on it that way you have a way of plugging in a light while keeping power to it for troubleshooting if needed.
#3 |
20 amp plug
What you describe is correct for a 120V/20A receptacle. It is also available in a duplex. But you MUST use a 20A receptacle. If it does not have the perpendicular(horizontal) slot, it is not a 20A receptacle and should not be used in a 20A circuit.
#4 |
My License Ain't 4 Sale..
20 amp plug
This is simply not true.
#5 |
20 amp plug |
#6 |
Licensed Electrical Cont.
20 amp plug
I think Bill is referring to a single receptacle.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
| Display Modes | |
| New plug for toaster oven? | mike720 | Electrical | 3 | 11-23-2008 08:44 PM |
| GFI Plug Troubleshooting | bryanchr | Electrical | 4 | 08-22-2008 06:28 PM |
| Is it safe to plug in this flourescent fixture? | doofalot | Electrical | 2 | 08-16-2008 02:27 PM |
| Avanti Electric Oven - But no Plug ? | hongtea | Electrical | 4 | 03-16-2008 09:07 PM |
