-   -   20 amp plug (http://www.diychatroom.com/f18/20-amp-plug-35016/)
MikeyP 01-03-2009 07:12 PM
20 amp plug
I'm installing a whirlpool tub on a dedicated 20 amp GFI circuit. I went to hardware expecting to buy a regular 2 plug outlet but I found a round single plug 20 amp 125 volt plug. It will take a normal plug but has an extra slot running perpendicular to one of the slots. Should I use this plug?
The one I was going to buy was 2 plug 15 amp
skymaster 01-03-2009 07:22 PM
I probably would use a 20 double ( duplex) outlet. My thoughts are just in case you have to get under it to work on it that way you have a way of plugging in a light while keeping power to it for troubleshooting if needed.
Just Bill 01-03-2009 07:24 PM
What you describe is correct for a 120V/20A receptacle. It is also available in a duplex. But you MUST use a 20A receptacle. If it does not have the perpendicular(horizontal) slot, it is not a 20A receptacle and should not be used in a 20A circuit.
InPhase277 01-03-2009 08:15 PM
This is simply not true.
jerryh3 01-03-2009 08:28 PM
Oh no! Not this discussion again.
Speedy Petey 01-03-2009 09:04 PM
I think Bill is referring to a single receptacle. :yes:
jerryh3 01-03-2009 10:04 PM
We'll see...:whistling2:
