20 Amp Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 11:20 AM   #1
Retired NYPD
20 amp outlet
Can I run a 20 amp. Circuit for both the fridge and the dishwasher? Or do I need 2 - 20 amp. Circuits?
FrankLa is offline   Reply With Quote
Old 03-07-2013, 03:01 PM   #2
By code you need 2 20 am circuits.
Someone will correct me if I am wrong!
Hardway is offline   Reply With Quote
Old 03-07-2013, 03:11 PM   #3
Electrician
Rewards Points: 150
If I remember right, as long as the combined amps are less than 16.5 (80% of 20A). And if one is hard wired, (no plug) it can't draw more than 50% of the circuit's amps. It's ok. However, this leaves no capacity for larger units. So, it's a perfect time to run a MultiWire Branch Circuit(MWBC). Run 12/3 with ground on a double pole breaker. Then at the first box split it into two 20A circuits.
Glennsparky is offline   Reply With Quote
Old 03-07-2013, 03:35 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Since it's a fridge I would just run two circuits one for each. If something ever happens and your dishwasher trips a breaker when you are not around it would cause your fridge to lose power on a MWBC.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-07-2013, 03:54 PM   #5
Electrician
Rewards Points: 150
Rrolleston is correct on the technicals. But I would only be concerned if this circuit were AFCI or GFCI. Since this circuit requires neither, the breaker will probably never trip. And people seldom run the dishwasher when they're away on vacation, so most people would notice the fridge was out within a few hours.
Old 03-07-2013, 04:04 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
OK, here is the scoop.
The refer can be on the SABC (small appliance circuit), OR it can be on a 15 or 20A INDIVIDUAL circuit. Meaning dedicated.
The DW can be on a 15A circuit, or a 20A circuit which can typically also then be shared with a disposal.
You CANNOT share the refer and DW.
See NEC 210.52(B)
The Following 4 Users Say Thank You to Speedy Petey For This Useful Post:
electures (03-08-2013), Hardway (03-08-2013), Jim Port (03-08-2013), stickboy1375 (03-07-2013)
Old 03-07-2013, 04:08 PM   #7
Electrician
Rewards Points: 802
Why can't you load a 20A breaker up to 20A.
darren is offline   Reply With Quote
Old 03-07-2013, 04:13 PM   #8
Because you can.
The Following User Says Thank You to Speedy Petey For This Useful Post:
jbfan (03-07-2013)
Old 03-07-2013, 04:45 PM   #9
dmxtothemax's Avatar
Rewards Points: 5,608
In real life you can !
But it may or may not work reliably,
chances are you will get nuisance tripping
thats why they say only load breakers to 80%
This is as far as you can push them reliably.
And thats why its been made code.
dmxtothemax is offline   Reply With Quote
Old 03-07-2013, 04:54 PM   #10
jbfan's Avatar
Rewards Points: 650
Can you post some facts and studies on this.
I've run 20 amp breakers at 22 amps for hours and never had a trip.
If a breaker is rated for 20, it should run 20 forever.
jbfan is online now   Reply With Quote
The Following 3 Users Say Thank You to jbfan For This Useful Post:
darren (03-07-2013), Jim Port (03-08-2013), stickboy1375 (03-07-2013)
Old 03-07-2013, 05:02 PM   #11
Electrician
Rewards Points: 802
80% rule has nothing to do with reliability. 80% is for continuous loads and this is done to prevent heat build up on the terminals.
If your breaker is rated at 100% you can run that breaker at full amperage forever with no real concerns.
Old 03-07-2013, 06:00 PM   #12
Sorry DMX, this is completely false. Especially the the code part.
Old 03-07-2013, 06:02 PM   #13
Electrician
Rewards Points: 150
See NEC 210.52(B)
Ok, I read it. There is no language restricting fridge and DW on the same 20A circuit. An individual 15A circuit is permitted for the fridge. But the code allows unlimited SABCs (... two or more ... 210.11(C)(1)). So any 20A circuit just becomes another SABC. I stand by my original posts.
Old 03-07-2013, 06:06 PM   #14
But the DW CANNOT be on a SABC. NOR can it be on with the refer.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Old 03-07-2013, 06:13 PM   #15
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would read the specs for the dishwasher. They usually tell you exactly what the dishwasher can be powered by and the manufacturer specs trump the NEC.
The Following User Says Thank You to k_buz For This Useful Post:
Glennsparky (03-07-2013)
Outdoor Outlet seansy59 Electrical 3 03-09-2012 03:50 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 09:36 PM
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
