20 Amp GFCI Circuit Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 09:22 AM   #1
20 amp GFCI circuit breaker
Can temperature be a factor in tripping the breaker?
Snalls is offline   Reply With Quote
Old 12-03-2011, 09:26 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Temperature of what?
Old 12-03-2011, 09:27 AM   #3
Rewards Points: 14,312
No, something else is tripping it, if that's really the question.
Old 12-03-2011, 09:32 AM   #4
In cooler outside temperatures the breaker never trips, but as warmer weather occurs it begins to do so. The warmer the outside temp the more frequently it trips. The breaker only services the lights and outlet in two bedrooms.
Old 12-03-2011, 09:46 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
More likely that you have a moisture condition at 1 of the outlets( receptacle or light fixture). When the temperature rises the humidity does also causing a high resistance leakage to ground.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
gregzoll (12-03-2011)
Old 12-03-2011, 09:52 AM   #6
Being a layperson, can I determine that or do I need to call a professional?
Old 12-03-2011, 09:52 AM   #7
Even a loose or poor connection can also cause it to trip.
Old 12-03-2011, 10:00 AM   #8
A "Handy Husband"
rjniles's Avatar
Depends on your comfort level and your mechanical abilities. Only you can make that determination.
Old 12-03-2011, 10:01 AM   #9
Yeah, but wouldn't you expect it to trip as well when the weather (air temp) isn't warm?
Old 12-03-2011, 10:08 AM   #10
I'm fairly comfortable and mechanically capable. Just need to know what to look for. I gather I will need to open each of the outlets and I suspect I will need to wait to do when the warm air temps return.
Old 12-03-2011, 11:17 AM   #11
A "Handy Husband"
rjniles's Avatar
Open all appearances of the circuit and look for loose connection. If any wires are backs-stabbed, connect directly to the screws or pig tail them. Look for signs of moisture, green corrosion.
Open the breaker panel and make sure the breaker & neutral connection are tight (turn off power when oping panel or pulling out switches and receptacles).
Snalls (12-04-2011)
GFCI as part of light circuit? iceracer Electrical 5 07-05-2011 08:05 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Can I replace a breaker w/ gfci myself secutanudu Electrical 12 07-28-2009 11:41 AM
How to connect switch to GFCI breaker? firemanter Electrical 3 10-28-2008 07:46 PM
