Is 20 Amp Fuse Cooked? Or Is It Me? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2013, 09:24 PM   #1
Is 20 amp fuse cooked? Or is it me?
Several weeks ago a carpet cleaner guy plugged his machine into my wall plug. The outlet now no longer works. I tried to put a gfi socket in and no juice. Went to main box and clicked the black 20 amp fuse on and off several times. Still no
juice. Is it possible that the fuse has been destroyed? It is a thin 20amp fuse
that slides into a slot. When I put GFI socket in I removed the old regular socket . I have never run into this but the GFI (for kitchen) had a warning and some tape on the socket that warned that you had to put it in right. I think I did
but only because I am at a total loss to figure out what to do next.
Thanks in advance.
humbleton is offline   Reply With Quote
Old 06-15-2013, 09:36 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
By the use of electrical terminology, I'd say your next step is to call an electrician.
The Following 11 Users Say Thank You to k_buz For This Useful Post:
electricalwork (06-16-2013), frenchelectrican (06-15-2013), Gac66610 (06-16-2013), gregzoll (06-16-2013), jbfan (06-16-2013), Kyle_in_rure (06-15-2013), mm11 (06-15-2013), old_squid (06-16-2013), Oso954 (06-16-2013), RWolff (06-15-2013), Speedy Petey (06-15-2013)
Old 06-15-2013, 10:32 PM   #3
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
There's no such bird in your house box as a "thin 20 amp fuse" it's a circuit breaker.
and yes, it's possible your circuit breaker is defective and needs to be replaced.
RWolff is offline   Reply With Quote
Old 06-16-2013, 02:26 AM   #4
Resi EC
Rewards Points: 252
Thanks in advance.
Did you turn the breaker all the way off(till it 'clicks'), then back on?
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 06-16-2013, 07:05 AM   #5
Rewards Points: 1,418
Thanks in advance.
Have you measured the voltage at the breaker terminal after you flipped the breaker back on?
Are any other receptacles dead?
Old 06-16-2013, 01:17 PM   #6
Rewards Points: 58
OP. Don't open that panel. Reset the breaker (check all of them in the panel) and if it still does not work, check all the GFCI receptacles around the inside and outside of the house.
Test each one by pushing the test button and then pushing in firmly the reset button.
Make sure its reset! All of them!
If you still have no power at the receptacle, call a professional.
Old 06-16-2013, 09:00 PM   #7
Roofmaster
Rewards Points: 2,172
Amen. Its not a socket, its a receptacle. A socket is something an auto mechanic uses. Its not a fuse, its a circuit Breaker. Fuses went out years ago. Do as this poster says, and then call a professional. Electricity can kill.
Tags
20 amp , gfi , no power
Fuse for chandelier with 12-volt transformer? S_Jeff Electrical 1 08-16-2012 12:19 AM
FA4BNF024 HVAC Unit - Blows 5 amp low voltage fuse intermitently ArmyChief HVAC 33 01-28-2012 02:22 PM
New Bryant Gas Furnace - Fuse Keeps Blowing DIYerIT HVAC 2 01-08-2012 05:22 PM
big fuse problem randallatha Electrical 6 01-02-2011 12:07 PM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-11-2008 12:20 AM
