20 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2008, 01:36 AM   #1
20 Amp Breaker
I'm using a 20 amp breaker for my shed wired with 12/2. I pretty sure its powering 1 light & 1 recep. on its way to the shed, but I know for sure the shed has 1 outlet, 1 light switch and I want to add a motion light.
Can I use 14/2 for my motion light? Or does it have to be 12/2?
The other thing is that, the recep. in the shed is bad, I have to look at the wiring first, but the bottom half of the recep outlet does not work.
evol200 is offline   Reply With Quote
Old 12-09-2008, 02:55 AM   #2
Yes it needs to be #12, if the breaker is 20A smallest wire that can be used on that circuit is #12.
As for your outlet, is it controlled by the switch, if not it could just be that the tab was broken off then all you need is a jumper from the top to the bottom.
Sliver is offline   Reply With Quote
Old 12-09-2008, 10:51 AM   #3
Nice.
No wall switch, the outlet will probably need a jumper from top to bottom like you mentioned, I'm assuming. They were installed by the same person.
Im curious though, what would happen if I do hook up 14/2 with 12/2?
Old 12-09-2008, 11:01 AM   #4
Originally Posted by evol200 View Post
Nice.
You will create a black hole and the earth will implode. Most likely nothing would ever happen, but the wire is not rated for 20A circuits, so don't do it.
jerryh3 is offline   Reply With Quote
Old 12-09-2008, 11:04 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
#14 cannot be protected by a 20A breaker the others have clearly stated.
So instead of bastardizing the circuit by putting #14 on it and replacing the breaker with a 15A just use #12.
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 07:48 PM
