Old 04-06-2009, 01:09 AM   #1
Send a message via AIM to theatretch85
20 Amp Bathroom Circuit
Re-wiring parts of my new house with the renovation project and I am curious if it is OK to run one 20 amp circuit for the outlets only in three bathrooms. The way I understand it, its ok for two bathrooms so long as its outlets only, or one bathroom lights and outlets on one 20 amp circuit is ok. Personally I hate dealing with 12gauge wire in a light box and would prefer to put the basement bath lights and fan on a separate circuit with the hall lights, bedroom lights and utility room/laundry room lights. Then another circuit for just the outlet, and eventually the upstairs bath outlets as well.
There are 3 bathrooms in total, basement bath, main bath, and master bath all right next to/above each other. Right now I am looking at a double switch box for the lights and fan with 14/2 in, and 14/3 out to the light box, continuing on to the fan/light combo with 14/3 as well. Then the basement bath outlet will have its own run of 12/2 in a separate box, potentially adding in a second outlet GFCI controlled since I have all the sheetrock off the walls at this point.
theatretch85 is offline   Reply With Quote
Old 04-06-2009, 11:36 AM   #2
Xtreme DIY'r
While you can do it, its not very practical
Some hair dryers use over 1500w
So if anyone uses a high wattage hair dryer & someone else tries to plug something in you will kick the circuit off
But if you are set on doing it make sure each bathroom is fed with line & not from the load of the other bathrooms GFCI
Line to 1st bath, this line feed will continue to the 2nd & 3rd bath
In each bathroom install a GFCI
Note if you exceed the wattage for the circuit you will need to go & reset the breaker, not the GFCI
Old 04-06-2009, 10:27 PM   #3
Re-thinking this I think I may just re-use some of the 12/3 romex I pulled out of the bathroom to feed the light, then the fan/light combo. Its not the new yellow jacketed cable, but it is 12/3 romex. Then I will just feed the downstairs bathroom on one 20 amp circuit for lights and the outlet(s).
I was really just trying to avoid having to buy 12/3 romex and to deal with 12 gauge wire in the light and fan boxes, but I figure re-using the 12/3 that was removed and keeping the bathroom all on its own 20 amp circuit would be the better way to go.
Old 04-06-2009, 10:33 PM   #4
Electrical Contractor
You can feed all the bath receptacles in the house with 1 20 amp circuit, but you cannot feed any lights with it.
Like scuba, not the best idea in the world.
Both of my baths share the same circuit, but I only charge a razor and the has the rest of the power.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Need a wiring diagram Mooreski Electrical 46 03-12-2011 04:25 PM
Bathroom must be on separate circuit? Jeremy Hillary Boob, PhD Electrical 2 11-29-2008 11:22 AM
Bathroom circuit ptcamaro Electrical 3 04-21-2008 08:44 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
