20 Amp Bathroom CIrcuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 01:30 PM   #1
Was a 20 amp circuit to a bathroom required in the 1997 NEC?
Mrlemonade is offline   Reply With Quote
Old 12-07-2011, 03:52 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
1996 or 1999?
Either way, bathroom receptacle circuit, yes, I think. Can someone confirm? I don't have my 1996 handy.
Old 12-07-2011, 03:59 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 528
It depends on what code cycle was in force at the time the house was built.
Some places may be out of cycle by 3 years or more.
My 96 book is at work Petey.
Old 12-07-2011, 04:54 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
delete
Kyle
Old 12-07-2011, 05:19 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
IIRC, I wanna say at least one 20A receptacle circuit was required for baths in the 1993 code. (Don’t think I have the book anymore). Also, think it might have been ’96 when the change was made to allow all of the bath to be on one 20A circuit.
Kyle
Old 12-07-2011, 07:35 PM   #6
Master Electrician
Rewards Points: 3,916
Nec 1996.
brric is offline   Reply With Quote
Old 12-08-2011, 07:25 PM   #7
retired union carpenter
Send a message via Yahoo to coupe
did you check your breaker box? should be marked and labeled if not? switch breakers off until you find receptacle you need to know? if is 20 amp? you can put in 20 amp receptacle. that's what I need for wife's sauna in master bath.
good luck
coupe
coupe is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Running New Circuit in Bathroom NashuaDon Electrical 1 10-18-2011 12:15 AM
adding new bathroom circuit debiasio Electrical 1 01-25-2011 06:48 AM
Bathroom light on a gfi circuit Debbo Electrical 1 04-28-2010 09:32 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
