20 Amp 240 Volt - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 08:38 PM   #1
20 amp 240 volt
I have a well pump that works on a 20 amp 240 volt plug. Generator does not have a outlet for this plug, but has a 30 amp 240 0utlet. How can I use this outlet on my generator for my well pump when I lose power to my pump.
Don Moore is offline   Reply With Quote
Old 07-12-2012, 09:28 PM   #2
Master Electrician
figure out a way to fuse it down to 20A and your good to go. Might have to run it through a 20A fused disconnect or equivalent.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-12-2012, 09:29 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The motor will have internal thermal protection, so I wouldn't worry about that aspect of it.
Old 07-12-2012, 09:34 PM   #4
Master Electrician
good point, and the gfci on the genny should still function fine. So really all he needs to do is build himself a cord with a 30A twistlock and a 20A receptacle then?
The Following User Says Thank You to andrew79 For This Useful Post:
Don Moore (07-13-2012)
Old 07-12-2012, 09:37 PM   #5
E2 Electrician
Thats my thinking on it... I was going to recommend a Reliance 2 circuit transfer switch, just to avoid the cord issue....
The Following User Says Thank You to stickboy1375 For This Useful Post:
24 volt AC wiring in same conduit as 220 volt single phase and in same outdoor enclosure as 220 v silgle phase and 3 phase arbailey Electrical 5 05-24-2012 08:43 PM
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 01:12 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 06:07 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 11:37 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
