#1 |
20 amp/220 v outlet
I live in a Chicago bungalow, built in 1926. The electrical service is grounded via a water pipe. When installing a 20amp 220v outlet, there are two brass terminals and a green ground. Should the the green grounding terminal be wired to the neutral bar, or grounded to the box. If I were to use a 20 amp 110v outlet there would be a brass and a silver terminal, as well as a green ground. Why is there no neutral terminal on the 220v outlet
Thanks |
#2 |
Licensed Electrical Cont.
20 amp/220 v outlet
If this is the main panel then the neutral and ground bars are the same thing. You can connect to either.
If this is a sub-panel then the ground goes to the ground bar. There is no neutral because there is NO neutral on a 220 volt circuit, simple as that. Two hots and ground.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
| Display Modes | |
| Electrical outlet hook up. | helpless handyman | Electrical | 4 | 07-30-2007 09:18 PM |
| Bathroom outlet - distance from tub?? | plbsplbs | Electrical | 11 | 07-09-2007 09:22 PM |
| 20a Outlet Vs. 15a Outlet | bobo | Electrical | 3 | 05-29-2006 11:55 PM |
| Adding garage outlet | Shane | Electrical | 1 | 02-23-2006 05:43 PM |
| European 220V outlet "Schuko" | estophile | Electrical | 6 | 08-27-2005 09:45 AM |
