I have added a set of 3 way switches to an existing light. It's a weird setup, so please bear with me as I explain.
Starting at the light box, I have the 2 wire feeding into the box from the panel. Out from the box is a 3 wire. The connections are black from panel to a separate black wire that carries on to other things from the switch box. White from panel and white from switch both to shiny screws. red from switch to hot on light.
I know the 3 wire is not usually required, but in this case, the black from the light that goes into the switch box is marred off to another wire that leads off to power a separate light.
Basically, I need to know how to wire the light and light box. I've tried a few combos that have resulted in either the light staying on and no power carried on to other lights, or blown fuses...
I'm fairly positive that the everything beyond the light is ok (my only question is should all the whites be marred together in that switch box?)
The problem I think I'm having is the fact that the black is currently providing power beyond the switch box. That is to say, the black is marred to another wire that leaves the switch box and carries on to power a plug and light in a different room...
This is the wiring as it stood before I did anything, with a regular 2-way switch at the end. I thought adding the 3 way would be a simple feat, but something must need to change in order to keep the juice flowing it seems...
Hopefully someone can help me out, the darkness is driving me crazy..
thanks
pry
