2 Wire Thermostat Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 11:02 AM   #16
Sorry
I was so engrossed in the subject and issues I didn't look at your location which I really don't do anyway.
My answer I guess is more geared for the Yankees. However it could be for the rebels if it got real cold at one time or another the occupant did the manual thing.
The reason could be lack of use valve not operational you know the saying use it or loose it.
SULTINI is offline   Reply With Quote
Old 10-18-2009, 02:21 PM   #17
No apology necessary .
I was just pointing out that I didn't think of that .
Even if you ever disagree with me . I rather a debate and we figure out the correct way or just settle to have a different opinion . As long as it's done in a respectful way , it's cool with me .
electro is offline   Reply With Quote
Old 10-18-2009, 05:28 PM   #18
DIY staff
Rewards Points: 7,174
Sometimes a good squirt of WD40 on the valve stem will give you a little more time out of a dying
valve like that.
Those actuator heads are always a bit loose,That one is probably a bit sprung from the previous owner using the manual over ride switch for so long.
Good luck,Just a guess--Did you buy this place 'as is' without hiring an inspector?
Old 10-19-2009, 05:06 PM   #19
valve like that.
We did have an inspector look at the place. But we purchased the place over the summer and the realtor told us that the heat is turned off in the summer so we did not investigate it any further
vtec69 is offline   Reply With Quote
Old 10-19-2009, 05:14 PM   #20
valve like that.
Well I just sprayed some wd-40 on the valve and turn the manual switch and now i have heat.
Going to let the heat cool down and then connect the thermostat back up and see if I have heat
The new head should arrive weds so hopefully that will compltly fix the problem
Electrical wire size question. shawnlee Electrical 11 08-11-2009 06:25 PM
wire running question ponch37300 Electrical 4 04-21-2009 03:58 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Thermostat Question Dekuyper Electrical 4 06-26-2008 07:49 AM
Thermostat question MsApril HVAC 1 02-09-2008 06:00 PM
