2 Wire Switch Connected To 3 Wire Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2010, 10:56 AM   #1
2 wire switch connected to 3 wire outlet
This may have been answered before, but I cannot seem to find it. I have home built in the late sixties, and while I've been able to figure out pretty much everything else, this perplexes me. I am trying to install a ceiling light where there was none before. There is an existing wall switch with standard 12/2(white and black) wire that runs to an outlet with 12/3 wire (white, black, red). This outlet, in turn, is run to the other two outlets in the room, all with the same configuration. However, the switch only runs the first outlet. I'd like to remove the switch so that the outlet is always hot, but jump off of the circuit to install the light. Any suggestions?
pacowboy78 is offline   Reply With Quote
Old 08-23-2010, 01:00 PM   #2
Rewards Points: 1,442
Firs you will have to describe to us all the wires and connections in the box with the switch controlled outlet. A picture is best.
A so describe the wires and connections in the box with the switch.
Old 08-23-2010, 02:55 PM   #3
joed's Avatar
Rewards Points: 11,992
This should tell you what you need to know.
http://www.selfhelpandmore.com/switc...plug/index.php
Old 08-23-2010, 03:19 PM   #4
The switch controlled outlet has the two white (neutral) wires running in and out the top and bottom of the left side (if you are facing it). The right side has a red wire out the top and a black wire out the bottom, both hot (120V). I've run a multimeter on the entire line of outlets, all of which are on the same breaker. Each outlet looks the same except the last one in series, which only has one neutral (white) wire. The white wires all read no voltage (or next to none, the multimeter always picks up something). At the switch, when tested individually, both the black and white wires read 120V. (Update, I have to get to the store in the AM, I think the switch is bad now because the outlets work all the time, regardless of on or off.)
Old 08-23-2010, 08:25 PM   #5
Which box does the power feed from the panel come into?
3 way wiring problem BillG Electrical 19 08-22-2010 09:58 AM
How do I wire these switches? keano016 Electrical 2 10-07-2009 11:19 AM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
trying to wire a light and light switch off of an outlet imphishy Electrical 3 03-16-2005 10:04 PM
