2 Wire Service And Laptop Computers - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 09:28 AM   #1
2 wire service and laptop computers
when our potential new (first) home was inspected we learned that it has a combination of 2 wire service and updated 3 wire service. the house was built in 1917 and the wiring was updated and a breaker box was installed in '03.
during the inspection the inspector mentioned that computers dont like 2 wire service outlets. does that apply to laptops as well? i was thinking no since my power cord is not a 3 prong plug and it converts whatever power it gets over to DC to charge the battery.
am i wrong or do i need to string up a lot more 3 wire outlets? there are some in the house and we plan on adding a bunch of GFCI outlets when we move in.
gregdonovan is offline   Reply With Quote
Old 06-10-2009, 10:17 AM   #2
Enormous Member
skipjack's Avatar
Rewards Points: 87
Most laptop external power supplys contain some sort of power conditioner in them to handle any fluctuations and spikes in power (I know my Dell does). So, you should be okay in a two pronged outlet with your two pronged power supply.
skipjack is offline   Reply With Quote
Old 06-10-2009, 10:27 AM   #3
If you only have 2 prongs what would the added ground wire connect to. Computers with 3 prong plugs depend on the ground for a filtering path for noise but lap tops do not. They are basically self contained and the power cord does little more than recharge the batteries.
hayewe farm is offline   Reply With Quote
Old 06-10-2009, 11:07 AM   #4
DIY'r
ScottR's Avatar
... powering the computer is more than little more.
But agreed, if the power brick has no ground connection you'll be fine.
ScottR is offline   Reply With Quote
Old 06-10-2009, 01:24 PM   #5
that is what i was thinking. thanks. we only have laptops so we are good to go in that respect.
at one point one bedroom had the plaster ripped out and sheetrocked. however, whoever did the job didnt bother to update that room to 3 wire service.
Old 06-10-2009, 04:37 PM   #6
I think it is a faulty conclusion from symptoms he saw.
Old 06-10-2009, 04:43 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
BTW, Gfci's are a good idea and provide additional personnel safety, but they do not provide a ground. They do nothing to provide protection for a computer or a device with a 3 wire grounded cord.
Old 06-10-2009, 05:06 PM   #8
that is what i figured, thanks for the clarification. the bathroom has 3 wire but no GCFI.
Old 06-10-2009, 11:11 PM   #9
Rewards Points: 1,016
The GCFI could be somewhere else, and the outlets in the bathroom are downstream from the GCFI.
Old 06-11-2009, 01:42 AM   #10
liscenced electrician
Rewards Points: 538
older computers used to be much more prone to grounding problems. Newer computers it is less of an issue
jimmy21 is offline   Reply With Quote
Laptop is shutting off ruwilde59 PC Repairs & Upgrades 6 11-16-2007 11:51 PM
