Old 05-15-2012, 10:41 AM   #1
2 wire photocell?
I've taken over the electrical trim work in a house I'm building, after letting an electrician rough the entire home. I instructed the electrician to include a run for a photocell at the front of the house to control my garage lights. However, I noticed that he only ran a single 14/2 run to the photocell location. It seems, however, that there are only 3-wire photcells (black, neutral, red). I've tried utilizing the black as the hot (black to black) and red (red to white) on the load side, without using the neutral since I don't have the additional wires. Doing this just leaves the lights on all the time.
Why would the electrician run a single cable to the photocell? Is there a 2 wire photocell available out there or a 3-wire that can work in a 2-wire configuration?
lfwallace is offline   Reply With Quote
Old 05-15-2012, 10:53 AM   #2
Cruising into the sunset
JulieMor's Avatar
2 wire photocell?
He was probably thinking of a simple switch when he ran the wires. I've seen two wire photocells but I can't think of ever having installed one. Do an Internet search, just make sure it's rated for 125 volts.
JulieMor is offline   Reply With Quote
Old 05-15-2012, 11:53 AM   #3
2 wire photocell?
Can I just use the ground as neutral, since they're so closely related anyway?
Old 05-15-2012, 12:13 PM   #4
2 wire photocell?
no, you cant, lol.
give more info about the install, it may be easy to call him back to run a 14/2 to the light, and cutting/removing whatever is currently going to the light box.... rather than rewire with 14/3.
jcrack_corn is offline   Reply With Quote
Old 05-15-2012, 12:57 PM   #5
2 wire photocell?
Actually, let me rephrase my question. The photocell does not use ground. It's got a black, red, and white. The black is for hot, the red is for the load, and the white is for neutral. From the 14/2, I can wire black to black and the white to red (using the white as the return to load). This leaves the copper ground wire not used. So couldn't I just take the copper wire and hook it to neutral on both ends? The only difference between this and using an actual neutral is that there is no jacket around the copper wire.
Old 05-15-2012, 01:00 PM   #6
Code05's Avatar
2 wire photocell?
No, you cannot!!!
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
frenchelectrican (05-16-2012), Speedy Petey (05-15-2012)
Old 05-15-2012, 02:51 PM   #7
Just a DIY guy
2 wire photocell?
and I believe that is the critical difference. Unlike a ground, the third wire of the photocell (a neutral) has current flow as part of its regular operation. Thus, it has to be jacketed.
Can it be done the way you suggest? Sure.
Is it safe? Is it code? No and no.
M3 Pete is offline   Reply With Quote
Old 05-15-2012, 03:15 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
2 wire photocell?
The physical difference, yes. The practical difference, NOT A CHANCE!
They are NOT closely related either.
These two statements of your only prove that you are NOT experienced enough complete this project.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Code05 (05-16-2012), frenchelectrican (05-16-2012)
Old 05-16-2012, 12:59 AM   #9
" Euro " electrician
frenchelectrican's Avatar
2 wire photocell?
I wrote the underline that part whoever that electrician is done ran that 14-2 conductor there may misunderstood what your intened plan if that is true you will have to call him back and change that one to proper 14-3 conductor that is the only way you can get the photocell to function properly.
I never really trust the two wire photocell devices at all they are useally not worth a merde.
I always run 3 conductor and that useally take care of that.
Merci,
Marc
frenchelectrican is online now   Reply With Quote
The Following User Says Thank You to frenchelectrican For This Useful Post:
Code05 (05-16-2012)
Old 11-04-2012, 11:14 AM   #10
2 wire photocell?
I know this post is a little old, but I just stumbled upon it. I have a low voltage system from Vista. My system uses a timer (rpm-100) that has a two wire photocell. It only last 4-6 months before it burns out. Problem is, the photocell costs $28. Is there a relatively cheap two wire photocell that I can connect to the Vista photocell connector?
f800 is offline   Reply With Quote
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
